VCDS 908 Dual-K & CAN
Posted: 15 Dec 2010, 17:29
by livnik
I own a VAG COM 908 cable, I installed its drivers and VCDS diagnosis programme. I cannot setup Port COM as you have described in tutorial… (My OS is WIN XP SP3, Laptop Toshiba Satellite, 3 USB available). In Device Manager I have only USB controllers, and inside them it appears Ross-Direct USB Interface... I don`t know what to do next...
I tried to connect the interface to a Fiat Stilo 1.2, 16V this morning. The VCDS communicates very well with Stilo's ECU, but only in VCDS programme to OBDII (I knew that compatibility), but when I tried to connect the interface by means of multiecuscan, I couldn`t pass over the COM error.
Is there any problem with VAG 908 interface and drivers...!?
I am looking forward your answer.
Re: VCDS 908 Dual-K & CAN
Posted: 15 Dec 2010, 20:41
by ivica21
VCDS 908 cable not work with multiecuscan.You need vag kkl or elm327 1.3 or 1.4 version.
Posted: 16 Dec 2010, 03:46
by livnik
Thank you!
Posted: 17 Dec 2010, 10:00
by alfa156sarajevo
you need a older version of VAG COM interface! You need a VAG COM KKL USB cable version 409.1!
Posted: 18 Dec 2010, 06:23
by livnik
Thank you very much!
It`s clear to me now. I`m about to buy this recommended cable...
I found this one in my country, I hope it`s OK.
http://www.autoscan.ro/Interfata_KKL_(USB).htm
Posted: 20 Dec 2010, 09:54
by alfa156sarajevo
livnik wrote:Thank you very much!
Yes! It is OK! I have the same color... ;)
