Page 1 of 8
Grande Punto Cruise control aftermarket
Posted: 11 Dec 2010, 20:46
by crivez86
Hi everybody!
I'm a new user of Fiat ECU scan!
I need to activate the cruise control, that I installed aftermarket.
Someone of you can help me???
Many thanks in advance!!
Re: Grande Punto Cruise control aftermarket
Posted: 21 Dec 2010, 22:09
by fiatbravoemotion
It's impossible to add cruise control when you don't order this functionality when the GP was produced. I checked it on my GP Sport from 2006 year of production. I have electrical installation with 2 wires to cruise control. I replace switch under steering wheel to switch with cruise control. I can do that green light of CC is lightning by Examiner. Trouble is body computer, where isn't phisicaly a few resistors. I checked this with Delphi documents and this is true. There are 2 versions of body computer to GP. With and without functionallity CC.
Posted: 20 Apr 2011, 07:55
by Thibag64
Hello fiatbravoemotion,
I am trying also to add the cruise control to my GP but you said it is impossible.
There is only one cable between the switch and the body computer for the cruise control. It is not there on my GP and need to add it.
Could you please give me the information on the different delphi body computers that you mentioned?. How can I know that my body computer is compatible with the cruise control?
Posted: 20 Apr 2011, 21:33
by EnIgMa
that's strange because i heard a lot of people here in italy has added the CC, with or without the wires...
Posted: 22 Apr 2011, 08:39
by Thibag64
Hi EnIgMa,
Do you now if some option in the GP body computer needs to be activated for the CC to work, or is it like "plug and play", as I heard for the fiat Stilo.
Posted: 29 Apr 2011, 10:07
by dallas140cv
The CC need to be activated in the body computer, Grande Punto isn't like other vehicles where you has only to cable wires or mount commands.
Posted: 03 May 2011, 07:18
by Thibag64
Do you know if it is possible with FES? I got the last version of FES (2.8) but didn't find the option to activate the cruise control in any module (structure, engine,...)
Posted: 03 May 2011, 08:02
by yani
Thibag64 wrote:Do you know if it is possible with FES? I got the last version of FES (2.8) but didn't find the option to activate the cruise control in any module (structure, engine,...)
No, it is not possible yet.
It will be very helpful if someone can send me "CAN Info" or PROXI reports from a car with CC and car without CC.
Posted: 04 May 2011, 07:01
by Thibag64
OK, I can easily provided for my GP, so without cruise control, need to find someone else for the cruise control GP
Posted: 05 May 2011, 14:48
by Thibag64
Thanks Yani for your help.
Here are the "CAN info" and PROXI reports for my Grande Punto (so without CC).
Tell me if it is what you need. I should get the same for a grande punto with CC soon.
01/01/2002 00:09:04
CONNECTED TO:
FIAT GRANDE PUNTO 1.3 MJET 16V
CAN Info
List of configured control units :
Body Computer Node (NBC): Present
Engine Control Node (NCM): Present
Electric Steering Node (NGE): Present
Dashboard Node (NQS): Present
Steering Wheel Controls Node (NVO): Not present
Receiver Radio (NRR): Present
Brake System Node (NFR): Present
Info-Telematic/Convergence Node (NIT/NCV): Not present
Driver Door Node (NPG): Not present
Boot Node (NVB): Not present
Climate Control Node (NCL): Not present
Automatic Transmission Node (NCA-NCR): Not present
Steering Angle Sensor Node (NAS): Not present
Parking Brake Control Node (NPB): Not present
Ceiling Node (NIM): Not present
Side Acceler./Yaw Node (NYL): Not present
Adaptive Cruise Control Node (NAC): Not present
Passenger Door Node (NPP): Not present
Driver Seat Node (NAG): Not present
Assisted Braking Node (NBA): Not present
Passive Entry Node (NPE): Not present
Steering Lock Node (NBS): Not present
Gearbox Selector Node (NSC): Not present
Passenger Seat Node (NAP): Not present
Parking Sensor Node (NSP): Not present
Engine Signals Node (NSM): Not present
Airbag Node (NAB): Present
Air Suspension Node (NMA): Not present
Roll Control Node (NRC): Not present
Self-adaptive Headlamps Node (NFA): Not present
Receiver Radio/Radio Navigator Node (NRR/RMN): Not present
List of active control units :
Body Computer Node (NBC): Active
Engine Control Node (NCM): Active
Electric Steering Node (NGE): Active
Dashboard Node (NQS): Active
Steering Wheel Controls Node (NVO): Not active
Receiver Radio (NRR): Active
Brake System Node (NFR): Active
Info-Telematic/Convergence Node (NIT/NCV): Not active
Driver Door Node (NPG): Not active
Boot Node (NVB): Not active
Climate Control Node (NCL): Not active
Automatic Transmission Node (NCA-NCR): Not active
Steering Angle Sensor Node (NAS): Not active
Parking Brake Control Node (NPB): Not active
Ceiling Node (NIM): Not active
Side Acceler./Yaw Node (NYL): Not active
Adaptive Cruise Control Node (NAC): Not active
Passenger Door Node (NPP): Not active
Driver Seat Node (NAG): Not active
Assisted Braking Node (NBA): Not active
Passive Entry Node (NPE): Not active
Steering Lock Node (NBS): Not active
Gearbox Selector Node (NSC): Not active
Passenger Seat Node (NAP): Not active
Parking Sensor Node (NSP): Not active
Engine Signals Node (NSM): Not active
Airbag Node (NAB): Active
Air Suspension Node (NMA): Not active
Self-adaptive Headlamps Node (NFA): Not active
Receiver Radio/Radio Navigator Node (NRR/RMN): Not active
Control units' power mode (Logistic Mode):
Body Computer Node (NBC): Normal
Engine Control Node (NCM): Normal
Electric Steering Node (NGE): Normal
Dashboard Node (NQS): Normal
Steering Wheel Controls Node (NVO): Normal
Receiver Radio (NRR): Normal
Brake System Node (NFR): Normal
Info-Telematic/Convergence Node (NIT/NCV): Normal
Driver Door Node (NPG): Normal
Boot Node (NVB): Normal
Climate Control Node (NCL): Normal
Automatic Transmission Node (NCA-NCR): Normal
Steering Angle Sensor Node (NAS): Normal
Parking Brake Control Node (NPB): Normal
Ceiling Node (NIM): Normal
Side Acceler./Yaw Node (NYL): Normal
Adaptive Cruise Control Node (NAC): Normal
Passenger Door Node (NPP): Normal
Driver Seat Node (NAG): Normal
Assisted Braking Node (NBA): Normal
Passive Entry Node (NPE): Normal
Steering Lock Node (NBS): Normal
Gearbox Selector Node (NSC): Normal
Passenger Seat Node (NAP): Normal
Parking Sensor Node (NSP): Normal
Engine Signals Node (NSM): Normal
Airbag Node (NAB): Normal
Air Suspension Node (NMA): Normal
Self-adaptive Headlamps Node (NFA): Normal
Receiver Radio/Radio Navigator Node (NRR/RMN): Normal
CAN CONFIGURATION DATA:
6F 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00
33 38 31 39 39 30 31 30 36 38 33 4F 55 54 50 55 54 2D 4A 49 54 20 07 07 12 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 41 40 03 07 3F 00 2A 10 83 80 00 06 00 00 00 84 06 01 02 00 00 00 00 00 3A 51 05 0C 0D 00 00 00 00 00 00 00 00 11 0D 50
CURRENTLY CONFIGURED CAN MODULES:
Airbag Node (NAB)
CURRENTLY AVAILABLE CAN MODULES:
Airbag Node (NAB)
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
Airbag Node (NAB)
01/01/2002 00:08:29
CONNECTED TO:
CURRENTLY CONFIGURED CAN MODULES::
Airbag Node (NAB):
CURRENTLY AVAILABLE CAN MODULES::
Airbag Node (NAB):
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
Airbag Node (NAB):
