Good evening to all,
I would like to modify a cordon VAG to be able to connect in the airbags of Stilo 1.6 of 2002, but I do not manage to understand(include) indeed where I have to connect the pin n°3.
Would it be possible to have a little more explanation, please?
Beforehand thank you
Connection airbags stilo 1.6
Re: Connection airbags stilo 1.6
you must have seen
see auditional tips on
http://www.multiecuscan.net/HowToUse.aspx
it,s pin7 in the kkl-(vag) eobd connector connected on pin 3 to
3+7
works on my mw stilo
good luck
3+7
good luck
hi, I use an easier way, connect the VAG, and works very well, I called three wires in the VAG, red wire terminal (16 Battery +) brown wire terminal (4 drums -) blue wire terminal 7 k line, with a male terminal at the tip, I can connect it anywhere on OBD2 car, the wires, red and brown, claws ligalos put the battery, and it was great.
Good evening,
Thanks to all for your answers...
just connect pin 7 and pin 3 and it should work!
