No fault codes with ELM, VAG no connection
Posted: 03 Dec 2010, 13:20
by bas
This morning, the MIL lamp lighted on(and still is ON, i cannot turn off the MIL).
With ELM i don't have any fault codes.
I cannot connect with vag-com(report sent 15 minutes ago).
I was trying to use English but without succes.
Fiat dealer told me that it is possible that with FES i don't see all fault codes.
He told me that I should come to him and connect to the Examiner.
HELP.
BAS
ps. Stilo 1.6 16V 103KM.
Re: No fault codes with ELM, VAG no connection
Posted: 03 Dec 2010, 19:30
by yani
I saw your log...
As I can see in the log any data transmission randomly stops for 5-10 seconds.
I think that you have some problem with the VagCom interface driver or setting or some other software on your computer.
Posted: 03 Dec 2010, 20:30
by bas
yani wrote:I saw your log...
I checked with 2 different vag-coms.
I'm using my windows xp only for car diagnostics.
What do You think about my MIL light and no fault codes?
BAS
Posted: 04 Dec 2010, 10:27
by yani
I'm 99% sure that you will get the same error codes with Examiner.
Maybe the error is not coming from the engine module. Try to connect to other modules (Body Computer, Dashboard) and check for errors..
As for the VagCom connection - That is really weird. You can install version 2.5 and try with it. Just uninstall 2.6 and install 2.5.
Posted: 04 Dec 2010, 10:52
by yani
Forget about the VagCom.... I found the bug which is causing this problem. Will post version 2.6.1 soon...
Posted: 04 Dec 2010, 13:48
by bas
yani wrote: I'm 99% sure that you will get the same error codes with Examiner.
Me too.
yani wrote: Maybe the error is not coming from the engine module. Try to connect to other modules (Body Computer, Dashboard) and check for errors..
I checked it at the very beginning..
yani wrote: As for the VagCom connection - That is really weird. You can install version 2.5 and try with it. Just uninstall 2.6 and install 2.5.
With 2.5 there was no problems with vag-com.
BAS
Posted: 04 Dec 2010, 17:07
by yani
Please try the new version 2.6.1. It should fix the problem with VagCom.
Posted: 04 Dec 2010, 20:54
by bas
yani wrote:Please try the new version 2.6.1. It should fix the problem with VagCom.
I'll do it tomorrow if the weather allow me do this(In Poland we have a fairly severe winter.).
I've solved problem with MIL light by disconnecting cables from engine ECU for 3 minutes.
BAS
Posted: 07 Dec 2010, 12:23
by bas
I just found a moment (I'm sorry that it was only today), Vag works. :)
BAS
