which interface for this sw support new CAN bus
peko
Post by peko »
hello friends
this sw support new protocol CAN to connect on alfa mtio ?
which interface ?
thank you
mattydr67
Re: which interface for this sw support new CAN bus
Post by mattydr67 »
Will be in new realese.
For CAN you can use ELM327 v1.3+ or OBDKey ( not right now )
For OBDKey you'll need to wait when Yani will finish support for it.
Foe now I will advise to use an ELM327 v1.3+
peko
Post by peko »
thank you friend
i have already vagcom interface , so i will test multiecuscan with vagcom interface
but i don't understand which modification must made on my cable.
vagcom interface need shint pins 1-7-9 ?
and pin 3 , i connect pin 3 with which pin ?
thank you
Pin 7 should be connected to Pin 1 and Pin 9 for engine, ABS, body
Pin 7 should be connected to Pin 3 is for Airbags.
Note Pin 7 is the ISO KKL signal pin.
IT IS NOT recommended to have both wiring modifications at the same time. That is 7 connected to 1,3 and 9.
I agree with s130!
more info you can find here: viewtopic.php?f=5&t=255!
Cheers ;)
