Hi all,
Just tried the software on my alfa 156 jts and all ok apart from when trying to connect to abs I get the following- dashboard lights up with abs errors, software reports an invalid iso code and shows latency as being to high. I have set the com port up as per instructions, any suggestions.
alfaasda
connection problem to abs
Re: connection problem to abs
it is normal for the car to show ABS lamp on dashboard when you connect FES and your VAG KKL interface to ABS mode. and when you disconnected the ABS lamp is off (despaired). this is normal!
and for "latency to high" I have no idea what to recommend you. I have same problem!
you will chose to door seting where the port to be used, and changes to lataci taime 2, and so it
The latency time is set to its lowest of 1 and the error of latency to high still shows.adão carlos vieira wrote:you will chose to door seting where the port to be used, and changes to lataci taime 2, and so it
I found the solution for this problem (latency too high)!
I installed new Microsoft .NET framework ver. 3.5 and after that I did not have any problems!
everything is normal!
good to know.alfa156sarajevo wrote:I found the solution for this problem (latency too high)!
