how to modify the cable vagcom
reparoyo
Post by reparoyo »
Hey guys, this is my first post and I want to solve a problem I have. First: I have a cable vagcom and want to make the modification of the pins 1,7,9 and 3. I understand the instructions that pins 1,7,9 have to make a bridge between them (in the photograph of the paguina see that the wires are bridged are the numbers 1,7,11), on the other side when I use the pin 3 with other pins must be connected, if the paguina on how to use it says do not connect to the pin 1,7,9. a greeting and have someone make me a sketch.
