Hi Yani,
The problem with Bosch Me 3.1 is still there on FES 2.5. As soon as one select a parameter FES disconnects from the ECU.
Selespeed is fine. Unfortunately I was out of reach of my WLAN on a breakdown out at Stellenbosch and could not send you the log file.
Maybe on your next version you could allow one to save the log file for later sending per e-mail.
Regards,
Dev.
Afa Selespeed Bosch ME3.1
Re: Afa Selespeed Bosch ME3.1
It seems to me that you are not talking about the same problem. I had a problem with a specific version of ME3.1 (the one in Alfa 156 Selespeed). It worked fine with ELM interface, but disconnected a few seconds after connection with VagCom interface.
I fixed this and yesterday one of the users reported that it is working fine in v2.5.
You are saying that "as soon as one select a parameter FES disconnects from the ECU". This is another problem. It is usually caused by slow computer. It can also be fixed by using an ELM interface because with the ELM interface the communication is not so time-critical.
Hi Yani,
That could be true as the Elm interface works fine.
It could also be that the KKL interface does not get enough power from the USB port.
Thanks anyway.
Your work is more appreciated than you will ever know!!!
Thanks,
Dev
Thanks anyway.
Thanks,
Dev
