How to read ABS & Airbag
Timppa83
Post by Timppa83 »
Hi!
I have 2 cars fiat stilo and alfa 156, and i have some obd cable and i have modified pins for it but can't get connection to Airbag,etc.
From fiat i managed to get information from motor ecu and power steering but not from Abs and Airbag.
and from alfa i got info from motor ecu and Abs, but not from Airbag.
I'm little confused... my cable dosen't work in Vag com interface, so is that problem?
Do i need Vag com cable to get all information from those cars and if yes. Can i connect with it to everything? motor ecu,airbag,abs,etc.....or do i need to have 2 differend cables depending what ecu i want to connect?
If connection problem is because that cable, if i bought Vag com cable, do i need to modify those pins for Abs,airbag?
Lot of questions,but hopefully someone can help me...
Re: How to read ABS & Airbag
Read this link carefully http://multiecuscan.net/SupportedVehiclesList.aspx
It clearly describes the commmunications/cable requirements.
