Connect to ECU IAW 18F 84 and 16F
Posted: 11 Sep 2010, 22:44
I bought a wire in the USB:
I've set everything according to the recommendations Multiecuscan FTDI chipset and is FD232BL downloaded from the FTDI drivers. Settings as is and on and on multiecuscan FTDI website. I also bought an adapter for Fiat:
My Settings:
Image on zip
Choose K-Line / VAGCOM How OBD Key chose not know what speed to choose write something about 10,400 but did not have.
I can not detect my ECU gets the message:
Any help suggestions?
He 's under one solution to connect to the ECU and worked.
here : http://www.fiatforum.com/cinquecento-se ... ct-10.html
A program to connect to the ECU at the cable, the drivers here :
http://www.elektroda.pl/rtvforum/download.php?id=408409
There's the source code of this program
Here you found information about reporting ECU codes and other settings:
http://www.elektroda.pl/rtvforum/download.php?id=408371
This may be useful. I confirm with my ECU IAW 18F 84 in the car Palio Weekend 1.2 8V 1242 73KW
The years 1999 merged and displays what is available from this program as:
Code ECU ISO
My Settings:
Image on zip
RPM: 1038 Inj: 0.532 IgnA: 33.0 MAP: 144 mmHG
Air: 35 Wat: 130 Thr: 31 (10.16) Bat: 13.94
Lmd: 128 ( 1.001) ISPos: 64 ISInt: 0 ISPrp: 0 TT: 0
0x00000010; 31 80 02 94 1C; ;
0x00000010; 31 80 07 94 A1; ;
0x00000010; 31 80 0E 97 AB; ;
0x00000010; 31 80 83 94 9D; ;
0x00000010; 31 80 85 94 1F; ;
0x00000010; 31 80 86 94 20; ;
0x00000010; 31 80 8F 97 2C; ;
0x00000010; 1; 1; 0x02; 0; 0; 0; 0x0000000A; 0; 0; 0; 0; 00 00 00 00 00; 0x0000; 1; 3; 20000; 2; 20; 90; 498; 4; 5; 20000; 2; 20; 2; 40; 2; 40; 2; 20; 7812; 0x0000; 0; 0x0000; 3; 75 40 B0 04; 0x8000; 0; 0; 3; 1000; 1000; 1; 0; 0x00; 3; 0F AA CC 00 00 00 00 00 00 00; 00 00 00 00 00 00 00 00 00 00; 00 00 00 00 00 00 00 00 00 00; 00 00 00 00 00 00 00 00 00 00; 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00; IAW 18F;
FIAT; PALIO; 1242 BENZINA; 0x0000000A; 1; 12; 17; 0x0000000A; 1;
FIAT; PALIO; 1242 BENZINA; 0x00000010; 1; 12; 17; 0x00000010; 1;
FIAT; PALIO; 1242 BENZINA; 0x00000019; 1; 12; 17; 0x00000019; 1;
FIAT; PALIO; 1242 BENZINA; 0x0000002A; 1; 12; 17; 0x0000002A; 1;
FIAT; PALIO; 1242 BENZINA; 0x0000005A; 1; 12; 17; 0x0000005A; 1;
FIAT; PALIO; 1242 BENZINA; 0x00000077; 1; 12; 17; 0x00000077; 1;
0x00000010; Iniezione Magneti Marelli IAW 18F;
