Page 1 of 2
Alfa 156 2.0 TS Selespeed ME 3.1 Breakdown
Posted: 30 Aug 2010, 16:27
by Agostinho
Hi Yani.
Every Time when i want to connect my ECU ME 3.1 the Connection break down after 5-8 sec.
On other ECU like ME 1.5.5 on the Alfa 156 2.0 TS of my daughter it works fine.
The Connection to the Selespeed is all right.
I have tried some other VAG KKl USB Cables, but it is always the same. The Connection breakdown.
I´m not the only one with this problem. Another Mate of mine got the same Trouble with his 2.0 TS 16V Selespeed ME 3.1.
What should be maybe the problem?
Thank you for answering, Ago.
edit: I use VAG KKL Interface
Re: Alfa 156 2.0 TS Selespeed ME 3.1 Breakdown
Posted: 30 Aug 2010, 18:09
by yani
Send me a report and I will check where the problem is.
That is the small red button "Send Report" on the bottom right in the main window of Multiecuscan. The button appears after disconnecting from the ECU.
Posted: 31 Aug 2010, 10:44
by Agostinho
OK Yani.
I´ll send you in the next Days the Report.
THX, Ago.
Posted: 23 Sep 2010, 06:51
by Agostinho
Hi Yani.
Today i have send you the Report.
Greetings, Ago.
Posted: 23 Sep 2010, 13:19
by yani
Thanks.
I saw the ME3.1 report and now I see where the problem is. Will be fixed in next release.
Posted: 23 Sep 2010, 21:08
by Agostinho
Super Yani.
This is one of the Reason why i bought your Program.
You fixed the failures so fast like a dessert storm.
I love to work with professionals.
THX, Ago.
Posted: 05 Oct 2010, 15:45
by yani
Can someone please confirm that this ME3.1 problem is fixed with version 2.5.
Posted: 10 Oct 2010, 14:14
by yani
Anyone to confirm that this ME3.1 problem is fixed with version 2.5?
Posted: 10 Oct 2010, 15:51
by sele156
yani wrote:Anyone to confirm that this ME3.1 problem is fixed with version 2.5?
Sorry Yani , I wish I could but i can´t.
The VAG- Interface works fine with SELESPEED but still disconnects after a few seconds with ME3.1 even with Multiecuscan 2.5. Both the Motronic and Selespeed work fine with ELM 327.
Yours
Bernd
Posted: 10 Oct 2010, 16:51
by yani
Did you send report?
