Multiecuscan 2.4 RELEASED!
I just released Multiecuscan 2.4.
The changes are:
- Added partial support for OBDKey interface (CAN modules are not fully supported yet). Tested with OBDKey 1.40.
- Added Bosch Motronic M2.10.4 support
- Added Bosch Motronic ME 2.1 support
- Added Bosch Motronic MED7.11 support (AVAILABLE IN THE FREE VERSION)
- Added Alfa 147/GT Body Computer support
- Added Alfa 159 Body Computer support
- Added Fiat Croma Body Computer support
- Added Autoliv MY06 Airbag (Linea, Ypsilon) support
- Added SIEMENS MY06 Airbag (Bravo, Delta) support
- Added idle actuator reset for Bosch Motronic M1.5.5
- Added phonic wheel learn reset for Marelli IAW 4AF/4EF/59F/5AF
- Added Bosch ABS8/ABS57 calibration functions
- Fixed Bosch ABS 8 actuator problems
- Added "SEND DISGNOSTIC REPORT" function. Anyone who is experiencing problems connecting to some ECU can use the small red "Send Report" button on the main screen of Multiecuscan. The button appears after disconnecting from an ECU or after unsuccessfull connection attempt. This function is completely anonymous and does not send any private data.
In the next version I plan to add support for some old injection ECUs like M2.10.3, MA1.7, ML4.1, M3.7.1, M1.7, MSA 11.
I will also try to add support for Grande Punto.
autoholik
Re: Multiecuscan 2.4 RELEASED!
Post by autoholik »
YANI, thanks for the great work. The program is amazing ! ;)
FiatEUCScan REGISTRED
grandex
Post by grandex »
You wrote that next version of FES will (maybe) contain Grande Punto/500 support. In connection with this fact I have a question. When do you plan to release next verion? I think that a lot of users wait for this moment.
Thanks for good job,geets
Grandex
EnIgMa
Post by EnIgMa »
usually he releases upgrades once a month....more or less... ;)
Yani, really waiting for grande punto ^_^
Already put money on my credit/card waiting for THE release :D
OndraMarkow
Post by OndraMarkow »
Hi Yani .. Why do not use a modified version of the Czech 2.3.1 (LANG FILE)? Joined the new texts and translated ... Thanks
Fiat Marea Weekend 1.9 JTD 105 rv2000 Xenon look+Led,Boost control,EGR-OFF
Grande Punto 2010
VFR750 RC36
AlfaRed69
Post by AlfaRed69 »
new translation italian language for v2.4
Beppe ;)
Italian Language v2.4.rar
(21.28 KiB) Downloaded 554 times
OndraMarkow wrote:Hi Yani .. Why do not use a modified version of the Czech 2.3.1 (LANG FILE)? Joined the new texts and translated ... Thanks
I think that I used that file which you sent me for version 2.4. If that is not the case then it is definitely my mistake.
OndraMarkow
Yani OK, Everybody makes a mistake ... I know you're busy with the program .. translate the text for version 2.4 and send it to you
Grande Punto 2010
VFR750 RC36
jaboleq
Post by jaboleq »
yani wrote:Hi,
You mean Bosh MonoMotronic MA1.7.3 ecu ? If yes then I am going to buy this!
shagat159
Post by shagat159 »
Hi, is there a special handling to move in 2.4?
