Could someone help me, I have a ELM327 cable v1.3a and I connect pin 7 to 1 and pin 7 to 9 to gain access to ABS and Electric Steering ECUs, but when I try the connection the following error appears --> ELM327->ECU Connection failed.
The settings are ok 38400 for ELM cable in Multiecuscan program and 9600 to com port and when I connect to Engine, Service, Body, Dashboard ECUs everything is ok. The car is a Fiat Stilo 1.6.
I will appreciate some advice to connect to the ABS and Electric Steering ECUs...
Tks
