Alfa 147 air bag light
Posted: 31 Jul 2010, 20:16
by fen
My Air bag fault warning light is on.
I used the free version of Fiat ECU scan (2.3.1) and got the following errors
22 - Curtain airbag squib (passenger) Value too high Present 140
Can you confirm whether or not the free version allows you to clear this error once it has been fixed?
Or do I need the paid for version?
It just that the free version cleared down the following ECU errors
U1706 - Engine > ABS data line No signal Stored Light ON
P0500 - Vehicle Speed Signal No signal Stored Light ON
Re: Alfa 147 air bag light
Posted: 01 Aug 2010, 07:39
by yani
Yes, you can clear the errors with the free version.
Posted: 04 Aug 2010, 16:23
by pr_00f
When the error state is present, it will stay even after you clean it.
Because it's present and ECU will find it immediately and will store it in memory.
Sounds logical ?
Posted: 04 Aug 2010, 23:29
by bas
fen wrote:Present
U can erase stored errors, present errors cannot be erased.
Check cables and connectors of the curtain...
BAS
