My car : fiat panda 1.2 8v 2005
PC : Eeepc Win 7
ELM Interface : OBDKey USB
I try to connect Multiecuscan to the car with my OBDKey interface.
With Multiecuscan, when I laught a test connection I have :
In 9600bd : response ? for each module
In 38400 bd : timout
It's working fine with the OBDKEY software.
Someone use this OBDKEY ELM interface ?
Thanks for your help
ELM interface OBDKEY USB not working
Re: ELM interface OBDKEY USB not working
The ODBKey interface is not exactly 100% ELM compatible. It is not supported in current version.
I'm already in contact with the manufacturer of the OBDKey and making tests with this interface.
I think that it could be supported in the next release.
Yani, what about other interface? I mean for example can interface like this one : http://www.peak-system.com/Product-Deta ... howUid]=16
Is the chance that Your software will be supported can interface?
Regards
pawzdy
Regards
pawzdy
I've some news about my problem ...
I return the interface to UK to the OBDKEY support.
They are very serious and upgrade my interface to a new 1.4 version and test with the Multiecuscan.
I receive the interface with a technical manual to use with multiecuscan.
It's working better : I can use the "test" function and all check are OK.
The USB connection use "ELM Bluetooth" mode in Multiecuscan.
I can connect to the ECU "EOBD Injection" : OK,
But I can't connect to other ECU : AirBag, ABS, Service : I have error message Timeout or Connexion Problem.
The "ELM Bluetooth" mode is working fine ?
or the next version off Multiecuscan will support better this mode ?
There will be separate (not ELM BT) support for OBDKey 1.40 in the next release of Multiecuscan.
I'm still working on this.
Ok, so I'm waiting for the next multiecuscan release,
thanks.
Amael
thanks.
Amael
Hi warma,
This may be helpful. I have a Panda 1.2 8V 2004 and can connect ok with FES using an ELM327 1.2a but only at 9600 baud.
I cannot connect to the ABS or Power Steering because they are on the C-CAN and I am using the free version of FES which does not support C-CAN.
Regards ~ Chris
Regards ~ Chris
