yesterday I was using 2.2.1 I think, and the Stilo Selespeed function "Clutch Pedal Position" is not longer present in 2.3.1 or it changed names.
Do you guys know whats it called now?
thanks
Clutch Pedal Position changed name? whats it called now?
Re: Clutch Pedal Position changed name? whats it called now?
I wont profess to know all about this software, but I was adjusting my clutch rod position the other day and compared both version 1.6 and 2.3.1.
My readings were :
v1.6
Clutch Eng Pos (selfadj) 27.804mm
Clutch Pedal position 27.846mm
Clutch pressure plate ref 27.846mm
v2.3.1.
Clutch pressure plate travel 27.846mm
I can only presume from this (by the process of elimination) that the old pedal postion mabe now called clutch pressure plate travel and has now changed places...............maybe ?
My readings were :
v1.6
v2.3.1.
maybe
Is yani back from vacations? I'm hoping he knows the default push rod distance for stilo selespeed. I can't find that information anywhere.
thanks
thanks
Sorry, I cannot follow all topics...
In version 2.3 I renamed "Clutch Pedal Position" parameter to "Clutch Pressure Plate Travel". I did this because I saw that in Examiner it is called this way and it seems more correct.
thank you!
Do you know the default distance in mm for stilo selespeed? is it 28.5mm like the alfas selespeed?
thanks
thanks
