Multiecuscan 1.4 Released
Posted: 12 Dec 2009, 19:58
by yani
I released version 1.4 today. These are the major improvements:
- Added Marelli SELESPEED CFC208F support
- Added Marelli SELESPEED CFC209F support
- Added Lucas EBC 430 ABS support
- Added TRW Electric Power Steering support (you need to connect your cable to pin 9 for this ECU)
- Improved communication stability on slower systems
- Added checking for new versions on starup
Re: Multiecuscan 1.4 Released
Posted: 13 Dec 2009, 12:34
by emil1310
Please add.....Fiat punto 1242cmc 16v YEAR 2000
cod ECU BOSCH ME 7.EH4.
My engine not start....
Posted: 13 Dec 2009, 17:34
by kecka
Today I tried ABS ,but wrote me this error : Invalid ISO code for.........
And it shows no data...
Thanks for the info
Posted: 14 Dec 2009, 08:19
by alfabug
Yani,
I tried ver1.4 on 156 Selespeed Petrol car. Unfortunately it can't communicated it and can't established the connection with Selespeed gearbox. Is this version only talking to Diesel/JTD selespeed?
alfabug
Posted: 14 Dec 2009, 13:18
by yani
Try to connect again. It should connect correctly the 2nd time. I will try to investigate the problem and release a fixed version.
Yani,
It should work for all Fiat/Alfa/Lancia cars that have selespeed CFC208F or CFC209F. Just to note that the selespeed gearbox is connected to pin 7 of the diagnostic connector.
Posted: 15 Dec 2009, 02:13
by alfabug
Yani,
It should work for all Fiat/Alfa/Lancia cars that have selespeed CFC208F or CFC209F. Just to note that the selespeed gearbox is connected to pin 7 of the diagnostic connector.[/quote]
It didn't. i tried on both petrol version of 156 and 147 2.0 selespeed. Both facing connection issue and not able to get "connected" signal. I was excited
but it can't
Posted: 15 Dec 2009, 16:33
by yani
Hi Guys,
I just posted an updated version - Multiecuscan 1.4.1
The only improvement is a fix in the connection code.
I hope that all problems when connectiong to the ABS or Selespeed will be resolved.
Posted: 15 Dec 2009, 18:59
by kecka
Posted: 19 Dec 2009, 23:22
by alfabug
Tested and cannot connect to Fiat Multipla 1.6 JTD with Bosch EDC15C7 ECU, very hunny...
however, on petrol version with IAW ECU, no problem
Posted: 20 Dec 2009, 18:22
by yani
alfabug wrote:Tested and cannot connect to Fiat Multipla 1.6 JTD with Bosch EDC15C7 ECU, very hunny...
Fiat Multipla 1.9 JTD can be either "Bosch EDC15 Diesel Injection (1.9)" or "Bosch EDC15C7 CF3/EOBD Diesel Injection (1.9, 2.4)". Did you try both of them?
