ABS actuator test
ttlogan
ABS actuator test
Post by ttlogan »
Actuator tests do not work in the ABS!
(Fiat Stilo 1.4)
Fiat stilo 1.4
Re: ABS actuator test
Which type of ABS do you have?
Please note that some tests require the engine to be running while others require the engine to be stopped.
ttlogan
Post by ttlogan »
HI Yani!
My ABS type Bosch ABS 8!
Test does not allow any,but I'll try again tomorrow!
Have any idea what could be the problem?
Fiat stilo 1.4
ttlogan
Post by ttlogan »
It is only natural to connect TO THE ABS with EBD FAILURE and ABS FAILURE
message to the instrument panel display?
Fiat stilo 1.4
ttlogan
Post by ttlogan »
Hi!
Today I tried again, but it does not work either in Actuator test!
Regardless of whether the engine is running or stopped!
Fiat stilo 1.4
Does it give you an error message?
Or, it runs but nothing happens?
What type of interface do you use (VagCom or ELM)?
ttlogan
Post by ttlogan »
Hi Yani!
Modified Vagcom cable!
Error message: Failed to execute
The lower left corner: Sometimes too high Latency
Is the port settings for me "1" latency
Fiat stilo 1.4
lybra2.4jtd
Post by lybra2.4jtd »
Hi Yani!
I have a vag-com cable and I successfully connect with ABS ECU. But shows the errors for ABS and EBD failure message to the instrument panel display. :? When I disconnect the ECU, the errors disappear.
Why this happened? What is wrong :?:
Thanks for help.
lybra2.4jtd wrote:Hi Yani!
Thanks for help.
That is normal. There is nothing wrong.
adibadi
Post by adibadi »
Hi!
I have a 1.4 8v Fiat Albea. I can connect to the ABS, read parameters but can't test any of the actuators. Appears to be doing but nothing happens, there is no sound nor any solenoid and the pump motor. KKL interface modified and Bosch ABS 5.3.
Regards from Romania!
