EGR tests not logged
cassador
Post by cassador »
Dear all,
During my fiat 500 EGR tests, I select on paramenters:
EGR Valve opening
Actual EGR Position
Desire EGR Position
EGR valve learn
EGR position control
after that, I got to "Actuatores" , choose EGR Solenoide valve and I can see the process and status ok.
The issue is I can't have this log..., the log results are the same (e.g.):
READING PARAMETERS:
EGR valve opening: 11 %
Actual EGR position: -0,142 mm
Desired EGR position: 0,000 mm
EGR position control: Disabled
READING PARAMETERS:
READING PARAMETERS:
EXECUTING ACTUATOR...
EGR solenoid valve
COMPLETE
cassador
Re: EGR tests not logged
Post by cassador »
In simulated connection, it logs well:
(Multiecuscan 5.4)
03/02/2026 13:22:11
Fiat 500 1.3 Multijet 16V
Marelli 8F3 CF5/CF5+/EOBD Diesel Injection (1.3)
SIMULATION MODE!!! THE DATA IS NOT REAL!!!
ECU ISO code: 7C 86 4F FF FF
VIN code: 5188214
ECU serial number: 281011421
FIAT drawing number:
Hardware number: 037367790
Hardware version: 44
Software number:
Software version: 0307
Homologation number: |?O??
Functioning time (EEPROM): 2089177087
Operating time: 2089177087
READING PARAMETERS:
EGR valve opening: 22 %
READING PARAMETERS:
EGR valve opening: 8 %
READING PARAMETERS:
EGR valve opening: 34 %
Actual EGR position: 49 mm
READING PARAMETERS:
EGR valve opening: 77 %
Actual EGR position: 69 mm
READING PARAMETERS:
EGR valve opening: 14 %
Actual EGR position: 84 mm
Both using OBDLink LX or Vgate vlinker FS USB
