Proxy alignment panda 312 fault
Posted: 06 Dec 2025, 10:02
by Alexvichi
Hi everyone, i have a problem with a fiat panda 312 0,9 twinair My 2015.I have the same common convergence error,iremove the blue & me module and install the android chinese system. When i do the alignment procedure with multiscan 4.8 it remove the convergence module but write a Entertainment Telematic Node (ETM).When i perform the alignement itfailed the ETM probably because it is a china radio.Now i have flashing odometer, multiscan says me that the alignement is not necessary. I will try disconnect the Android chinese carplay and multiscan run proxy alignment without ETM module.When the alignment is ended i turn off the key and riconnect multiscan for reset the error B10AA-4A - PROXI configuration control.
I have another odometer that flashing and appear B10AA-4A - PROXI configuration control. I have only one strange.When i perform the first alignment multiscan setting a engyne tiper with 1.3 turbo but i have 0.9 twinair.The tutorial say that don't touch everithing when perform the alignemt and i run the procedure with this method.
The engyne type could be a problem of B10AA-4A - PROXI configuration control? If i replace this type with type 6 or 7 for my
correct engine what could happen?I could try setting steering wheel controls for 8 to 4?
This is my configuration proxy
CAN CONFIGURATION DATA:
6F 00 00 05 02 00 00 00 4F 00 00 05 10 00 00 00 0B 00 00 00 10 00 00 00 09 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
6F 00 00 05 02 00 00 00 09 00 00 05 02 00 00 00 4F 00 00 05 10 00 00 00 09 00 00 05 10 00 00 00 09 00 00 05 10 00 00 00
30 36 33 31 39 30 31 30 38 37 38 4F 55 54 50 55 54 44 4A 49 54 20 15 03 19 6F 00 00 05 02 00 00 00 09 00 00 05 02 00 00
00 81 82 73 07 44 00 00 71 AA 00 00 06 00 07 00 84 06 15 02 1E 00 80 00 01 35 40 0A 3C 0D 00 80 0E 17 00 00 00 00 31 04
50 00 00 00 04 00 6B 00 02 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 02
Multiscan says me a warning that don't identify engine ecm Hardware number: MM8GSWHW612 - Ver: 00 Software number: D432HM45 - Ver: 0000
Thank yuo for reply
bye
Alessandro bye
