if want to remove original radio is possible to do it?
regards
ducato 250 2022
abarthmultijet
Re: ducato 250 2022
This ducato is probally equipped with an SGW. If you want to change an program certain things you need an SGW bypass.
Re: ducato 250 2022
yes it is with gateway, when connect to proxy it gives all ok exept
trailer tow node : added / EOL failed
its a 2021 ducato is gateway in BSI or is separate gateway??
there is a trailer mounted, but the proxy is not done if i understand it? trying to understand the proxy. not quit none with it
abarthmultijet
Re: ducato 250 2022
2021 is a borderline case. Could be both.. But there are a lot of posts and forums online where you can check if you have the build in version or the separate version
