Replacement of control unit and injector(s) fiat doblo 1.3
Posted: 03 Oct 2025, 20:14
by georgegiorgian
Hello!
Recently I replace on a Doblo 1.3 Mjt 75 HP 2008 marelli 6f3 the injectors.
I use the command Replacement of control unit and injector and the car wont start no more.
Afther this operation I Coded with an older vesion of mes with kkl cable and show completed. The car dosent start I did sometinhg wrong . Afther I replaced the injectors the car started run a while afther runing this procedure the car dosent start even if i coded the injectors with cantiecar and kkl cable. What should I do.
