help connecting to my stelvio!
Posted: 02 Oct 2025, 02:53
by duhjeff1977
I recently purchased a 2018 Stelvio. I was using the old blue Stardiag and grey plug (which i had it for my old giulia qf). for some strange reason, it won't connect anymore . just purchased the newest version and i read the help support and it says I need A5 and A6 plug? I'm a little confuse there.
Re: help connecting to my stelvio!
Posted: 02 Oct 2025, 08:03
You need to look/read for your exact models here: https://www.multiecuscan.net/SupportedVehiclesList.aspx
Posted: 02 Oct 2025, 11:19
by duhjeff1977
yes, but according to it. I'm using Stardiag (green one) and grey (A6) adapter.....I plugged it in but it won't let me connect no matter what I try....that's why I'm asking if theres another ELM 327 I should get or any would work with the adapter?
Magneti Marelli IAW 10JA CF6/EOBD Injection (2.0) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Magna Q4 Transfer Case |INFO|DTC|DTC EX|PRM|ADJ| ELM
ZF 8HP50/75 Automatic Gearbox |INFO|DTC|DTC EX|PRM|ADJ| ELM
ZF Electronic Gear Shift Module |INFO|DTC|DTC EX|PRM|ACT| ELM
Continental ABS MK C1 |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMA6
Driver assistant system module (DASM) radar Bosch |INFO|DTC|DTC EX|PRM|ACT| ELM
Haptical lane feedback (HALF) camera Bosch |INFO|DTC|DTC EX|PRM| ELMA6
Torque vectoring module (TVM) |INFO|DTC|DTC EX|PRM|ADJ| ELMA6
Bosch Airbag |INFO|DTC|DTC EX|PRM| ELMA6
Steering Lock TRW |INFO|DTC|DTC EX|PRM| ELMA6
ZF Electric Steering |INFO|DTC|DTC EX|PRM|ADJ| ELMA6
Service Interval Reset |INFO|DTC|PRM|ADJ| ELM
Amplifier module Ask/Beats |INFO|DTC|PRM| ELMA5
Engine sound enhacement module (ESEM) |INFO|DTC|DTC EX|PRM|ACT| ELMA5
Instrument Panel Continental |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Marelli AlfaConnect Radio/Nav |INFO|DTC|PRM|ADJ| ELMA5
Multimedia control module (multifunction knob/joystick/touchpad) |INFO|DTC|DTC EX|PRM| ELMA5
Body Computer Marelli (949) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
CAN Setup / PROXI Alignment Procedure (949) |INFO|ADJ| ELM
Radio frequency hub (RFHUB) Continental |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Comfort rear seat (CRSM) Bitron |INFO|DTC|DTC EX|PRM| ELMA5
Comfort seat and wheel (CSWM) Bitron |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMA5
TRW climate control (Automatic) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMA5
Automotive Lighting adaptive headlights |INFO|DTC|PRM|ACT|ADJ| ELMA6
Blind Spot Sensor Autoliv (Left) |INFO|DTC|DTC EX|PRM|ACT| ELMA5
Blind Spot Sensor Autoliv (Right) |INFO|DTC|DTC EX|PRM|ACT| ELMA5
Parking control Bosch |INFO|DTC|DTC EX|PRM|ADJ| ELMA6
Parking control Bosch (Rear only) |INFO|DTC|DTC EX|PRM|ADJ| ELMA6
Power liftgate (PLGM) BROSE |INFO|DTC|DTC EX|PRM|ADJ| ELMA5
Posted: 03 Oct 2025, 12:51
by shpuncik
both Giulia/Stelvio use same adapters blue/grey to access all ECUs. if you can't access it even without adapters it's either there is something wrong with your OBD connector or someone installed SGW bypass with separate OBD connector.
