Data file error
Posted: 27 Jul 2025, 19:19
by wuggi
I had the registered version 4.7 and installed version 5.3.
A message appeared saying that my license had expired and that I should revert to the old version.
So I reinstalled 4.7, but now I get a "Data file error" on startup.
Why don't you check the license before destroying a running installation?
How can I fix this error?
Thanks in advance.
Best regards,
Thomas
Re: Data file error
Posted: 27 Jul 2025, 21:01
I have not seen this mentioned before.
All I can suggest is that you uninstalled MES and then install V4.7 again.
Before uninstalling I would look at the MES install and data locations and copy all you find to a separate directory, preferably on a separate drive/USB stick.
Since V4.7 I suspect a lot has changed.
Old versions of MES / V4.7 can be found here: https://www.multiecuscan.net/ReleaseHistory.aspx
Re: Data file error
Posted: 27 Jul 2025, 22:35
by wuggi
Uninstall and install solved the issue.
