Change oil 0 km Fiat Ducato X250 3,0 Multijet Facelift
Roger Aasen
Post by Roger Aasen »
Hello.
I have tried to do the Oil change (Only for versions with DPF), using Iphone 15 pro MAX, licensed version, and OBDLink M+.
The oil degradation resets to 100%. The next oil change read from the ECU is 45000 km.
But i keep gettinge "Change oil", and the oil can flashing at ignition on.
And the display in the van keeps showing "Shange oil 0 km". Meaning there is 0 km to i need to change oil.
The oil is fresh, with only 1000 km.
Tried every tips i can find on the net, with ignition, throttle down 7 times, 3 times and so on, in the right order.
I found another guy here at the forum neded to go to a workshop using a SnapOn tool to get a complete registered oil change.
Anyone know if there is so ?
Thinking it's a little strange as I suppose this is a very basic function in this kind of scanning tool like Multiecusan ?
Re: Change oil 0 km Fiat Ducato X250 3,0 Multijet Facelift
oil reset should be done in two places - engine ECU and Service tab in MES.
Roger Aasen
Ok.
I have done the reset in the ECU.
When I go to the Service menu it first shows "ECU ISO code", and when I connect to this i get four choices.
Last service date, Service interval, Set number of service coupons, and NEXT SERVICE KM RESET.
Do you know who of them, and what to do ? I beleive that i have done the Next service km reset.
But can try again. ?
