Airbag Node (NAB/ORC): EOL Failed
Posted: 10 Jun 2025, 21:18
by ibelonginthekeys
When performing a proxi alignment on my 2024 Alfa Romeo Stelvio Q4, I am getting a timeout on the airbag module.
I have done the following troubleshooting/config steps so far:
  • Software: Updated to 5.3R1
  • Software: Interface set to ELM 327 HIGH SPEED and passes test
  • Software: Can connect to airbag module directly using grey adapter to read data
  • Software: Reset all codes in DTC scan and retry
  • Car: No weight on passenger seat
  • Car: No seatbelts buckled
  • Car: Disconnected battery and installed SGW
  • Port Settings: Set BPS to 115200
  • Port Settings: latency to 1
  • Port Settings: Set minimum timeout read/write to highest value
  • Performed full proxi alignment 5x times with no change in result, with key off for at least a minute after before restart
  • Diag: Captured PDF diagnostic report after latest attempt (attached), no apparent changes during any attempt
I am also getting all kinds of various warning lights and odometer flashing which I presume are due to the alignment not completing after module change, as they only happened after installing the SGW.
Any thoughts on what I am missing to get all the modules aligned? Thanks!
Re: Airbag Node (NAB/ORC): EOL Failed
Posted: 11 Jun 2025, 12:29
by shpuncik
there was problem with proxi alignment on airbag node on MY23/MY24 models not sure if it was fixed. try contacting support for more information.
Posted: 11 Jun 2025, 13:06
by ibelonginthekeys
Thanks I went ahead and did so. I wasn't able to find any mention of that issue elsewhere, and the module is listed as supported on the Vehicle Support list and there are no asterisks or warnings listed so hopefully there is a fix pending.
Restraint/airbag management
Bosch Airbag
Supported functionality:
Read identification details, Read/clear error codes, Read error code details, Read up to 47 live data parameters
Possible to connect with following interfaces/adapters:
ELM 327/OBD Direct-Protect/Generic OBD+GRAY adapter A6
OBDLink SX/MX/MX+/LX+GRAY adapter A6
Vgate vLinker MC/MC+/BM/BM+/FD/FD+/FS+GRAY adapter A6
Vgate vLinker MS
CANtieCAR
Posted: 30 Jun 2025, 17:43
by chrener
Do proxi alignment with all seatbelts unlocked and with closed all doors...
Posted: 01 Jul 2025, 08:21
by shpuncik
btw, I have seen somewhere that using OBDLink cable instead of ELM327 proxi alignment was done successfully. haven't tried it myself for the moment.
