Fiat 500 (2013) New Android Head Unit
Aidan Aus
Post by Aidan Aus »
Hi all,
I have installed a No name Android head unit with CarPlay etc and even after disconnecting the Blue and Me Power manually and completing a Proxi Alignment, I still have the flashing ODO.
I think it’s due to the system adding the ETM module.
Does anyone know how to code out ETM?
Also, how to turn off Stop and Start as if I mark it as not present, the car will not start.
abarthmultijet
Re: Fiat 500 (2013) New Android Head Unit
Post by abarthmultijet »
Start stop function off you can not do with Multiecuscan, you need to go to an ECU tuner.
Aidan Aus
Post by Aidan Aus »
abarthmultijet wrote: 21 Apr 2025, 08:33 Start stop function off you can not do with Multiecuscan, you need to go to an ECU tuner.
Thank you.
Any idea on the ETM code out?
abarthmultijet
If after an failed Proxy allignment, you can go to the home screen, and press the pdf icon in the lower right corner. This file will tell you what the car doesn't like about the current proxy code.
Aidan Aus
Post by Aidan Aus »
abarthmultijet wrote: 22 Apr 2025, 19:42 If after an failed Proxy allignment, you can go to the home screen, and press the pdf icon in the lower right corner. This file will tell you what the car doesn't like about the current proxy code.
I have don’t that.
It’s the ETM it doesn’t like, problem is, I don’t know how to code it out.
abarthmultijet
Aidan Aus wrote: 27 Apr 2025, 02:37
I have don’t that.
You have done it or you have not done it?
