Ducato - Empty PROXI file in Body Computer (BCM)!
georgedani
Post by georgedani »
I am trying to connect to CAN Setup / PROXI Alignment Procedure (290) and software keep returning the following error
"Empty PROXI file in Body Computer (BCM)!"
I tried to get the DTC scan and here are the errors that i am receiving
(Multiecuscan 5.3R1)
11/4/2025 21:06:19
Fiat Ducato (type 290) 2.3 Multijet
Body Computer Marelli (290)
ECU ISO code: BF 83 8F 0D B3
VIN code: (removed by me)
ECU serial number: (removed by me)
FIAT drawing number:
Hardware number:
Hardware version: 04
Software number: 04440009201
Software version: 0405
Homologation number: 000029
Functioning time (EEPROM): 467958
Operating time: 467962
Startups counter: 10855
VIN lock status: (this is empty)
PROXI configuration write counter: (this is empty)
READING ERROR CODES:
1. U1736-87 - Convergence Telematic Node (NCV)
Operating time: 467946 min
Startups counter: 10849
2. U1732-87 - Tire pressure control unit (TPM)
Operating time: 467958 min
Startups counter: 10854
3. U1703-86 - Instrument Panel node
4. U0019-88 - B-CAN line
5. B10AA-4A - PROXI configuration control
Operating time: 467948 min
Startups counter: 10850
Operating time: 467950 min
Is it my cable? I am using the yellow connector along with an ELM 327 version 1.5
Thank you in advance
Re: Ducato - Empty PROXI file in Body Computer (BCM)!
scan whole car and check for weird CAN bus errors. could be your cable or could be something on CAN bus network which prevents getting proxi config.
