Lancia Delta 2011 factory default proxy configuration
Posted: 01 Apr 2025, 08:06
Hi all, can somebody please share custom proxy configuration from Lancia Delta ?
My current car configuration is this:
Unfortunately, this not default factory configuration because in the past I used Android radio head and this change requested car configuration change (Radio MAPNAV disable). After I switched back to factory InstantNav which requested again configuration change (Radio MAPNAV enable).
This change is not supported in MES and I needed to use AfaOBD tool which not support backup of proxy configuration for my car and I also didn't have MES licence so at the end I don't have factory default configuration backup for my car
Now, some functionalities of ma car is not working:
automatic volume control based on car speed (SVC)
hydraulic brake assist (HBA) in case of emergency brake
hazard light switch on in case of emergency brake
radio RDS data
Thank you for any hints
30 34 31 38 31 30 30 38 37 34 36 4F 55 54 50 55 54 2D 4A 49 54 20 11 09 27 EF 04 00 25 A9 04 00 04 C1 09 00 07 8F 2B 17 07 40 0A 85 06 01 46 05 2E 40 81 86 43 00 84 00 00 02 00 00 00 00 00 76 51 0A 0C 01 00 00 00 3A 20 B8 00 22This change is not supported in MES and I needed to use AfaOBD tool which not support backup of proxy configuration for my car and I also didn't have MES licence so at the end I don't have factory default configuration backup for my car
radio RDS data
