Proxy alignment Radio Navigator Node (NRR/RMN) FAILED! - Timeout error
Frosty85
Post by Frosty85 »
Hi, after some time with Android radio unit I switched back to factory InstantNav radio unit, but this step required car proxy configuration for my Lancia Delta 2011.
In the past when I installed Android radio I disabled factory InstantNav unit using AlfaOBD in BCM configuration and executed proxy configuration. Everything worked correctly and no issue was present during proxy alignment.
Now, I enabled InstantNav and installed back factory InstantNav and executed proxy alignment, but proxy alligement is failing every time when is executed and is failing on writing configuration to Radio Navigator Node (NRR/RMN) with fail message FAILED! - Timeout error. The error is exactly same for MES and also AlfaOBD.
I'm using Bluetooth ELM 327 1.4 interface which is not recommended for proxy alignment, but based on the MES is fully compatible with ELM 1.4. Can somebody please can take a look on my configuration if everything is set-up correctly. In scan for interface in MES I see Latency too high !!! Can be resolved somehow or I need to switch to USB interface for example OBDLink SX ?
Scan for interface:
Please connect the interface to a car!
Scanning ...
ELM 327 / Generic OBD (Bluetooth) interface found at port COM3, speed 9600bps
Latency Too High!!!
COMPLETED
Test interface connection:
RESPONSE: ATZ
ELM327 v1.4
ELM327 v1.4
MES log after proxy alignment:
CAN CONFIGURATION DATA:
25 00 04 EF 25 00 04 EF 00 00 04 01 00 00 04 00 00 00 00 00
25 00 04 EF 04 00 04 A9 25 00 04 EF 04 00 04 A9 04 00 04 A9
30 34 31 38 31 30 30 38 37 34 36 4F 55 54 50 55 54 2D 4A 49 54 20 11 09 27 EF 04 00 25 A9 04 00 04 C1 09 00 07 8F 2B 17 07 40 0A 85 06 01 46 05 2E 40 81 86 43 00 84 00 00 02 00 00 00 00 00 76 51 0A 0C 01 00 00 00 3A 20 B8 80 22
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Info-Telematic/Convergence Node (NIT/NCV)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
Self-adaptive Headlamps Node (AFLS/NFA)
(Multiecuscan 5.3R1)
31. 3. 2025 17:49:19
Lancia Delta '08 1.9 Multijet 16V TwinTurbo
Receiver Radio/Radio Navigator Node (NRR/RMN): EOL Ok
Info-Telematic/Convergence Node (NIT/NCV): EOL Ok
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
Self-adaptive Headlamps Node (AFLS/NFA): Ok
CUSTOM PROXI NEW DATA:
30 34 31 38 31 30 30 38 37 34 36 4F 55 54 50 55 54 2D 4A 49 54 20 11 09 27 EF 04 00 25 A9 04 00 04 C1 09 00 07 8F 2B 17 07 40 0A 85 06 01 46 05 2E 40 81 86 43 00 84 00 00 02 00 00 00 00 00 76 51 0A 0C 01 00 00 00 3A 20 B8 00 22
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Receiver Radio/Radio Navigator Node (NRR/RMN) FAILED! - Timeout error
Writing to module: Info-Telematic/Convergence Node (NIT/NCV) SUCCESS!
FAILED TO EXECUTE
Frosty85
Re: Proxy alignment Radio Navigator Node (NRR/RMN) FAILED! - Timeout error
Post by Frosty85 »
Does anyone have an idea how to resolve my Timeout error ?
Should I buy OBDLink SX USB interface or my timeout error can be caused also wrong proxy configuration or faulty factory radio unit ?
Thank you for any response :)
Frosty85
Post by Frosty85 »
I can add latest status update...
After I switch to OBDLink SX and set-up latency timer to lowest value (1 msec) and connection speed to 115200 nothing changed. Still I have only Timeout error when data is written to InstantNav radio unit.
I need to execute proxy alignment because since I reverted back my factory InstanNav radio unit my AUX input is no longer working.
In my InstantNav these two options are missing:
Switch AUX input Off
Navigation messages off
I MES I see in my car proxy configuration option to enable AUX, but based on my issue with Timeout error when data is written to InstanNav during proxy alignment I cannot activate my AUX input.
On 17.4.2025 I also submitted diagnostic report.
Thank you for any suggestion :)
