i got boxer3 with blinking mileage , i think someone changed radio because vin in radio is difrent
can not complete proxy aligment
maybe someone can help solve problem
CAN CONFIGURATION DATA:
4B 10 00 04 10 00 00 00 4B 10 00 04 10 00 00 00 01 00 00 00 10 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4B 10 00 04 10 00 00 00 09 00 00 04 10 00 00 00 4B 10 00 04 10 00 00 00 09 00 00 04 10 00 00 00 09 00 00 04 00 00 00 00
30 38 32 35 30 33 38 39 34 38 33 4F 55 54 50 55 54 44 4A 49 54 20 19 04 05 4B 10 00 04 10 00 00 00 09 00 00 04 10 00 00 00 83 48 53 08 B1 00 7C 20 00 20 00 16 00 00 20 8C 06 0B 02 60 C0 90 56 00 05 00 15 04 00 00 00 00 57 00 20 00 00 42 00 C1 03 21 43 00 FF 00 85 00 A0 20 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 94 00 00 00 02 00 00 84 17 00 10 00 00 00 30 00 05 00 00 00 00 00 00 0E 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 01 00 00 1F 00 00 BB 00 00 02 FF
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Steering Angle Sensor Node (NAS)
Airbag Node (NAB/ORC)
(Multiecuscan 5.3R1)
22.03.2025 19:17:14
Fiat Ducato (type 290) 2.0 Multijet
CAN Setup / PROXI Alignment Procedure (290)
Steering Angle Sensor Node (NAS): Ok
Airbag Node (NAB/ORC): EOL Ok
Entertainment Telematic Node (ETM): EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Unknown error
[102A] errors: Byte 115: 17->10
FAILED TO EXECUTE
and this is from radio
22.03.2025 19:25:38
Uconnect Radio/Nav 5"
ECU ISO code: B5 83 19 0B 31
VIN code: VF3YBTMFB12B05333
ECU serial number: BD3400426001100
FIAT drawing number: 735625821
Hardware number: F.EU.D2.V22
Hardware version: 22
Software number: 06.00.48.01
Software version: 0600
Homologation number: 031634
Functioning time (EEPROM): 42725
Operating time: 42731
Startups counter: 28099
VIN lock status:
PROXI configuration write counter:
Boxer proxy problem
abarthmultijet
Re: Boxer proxy problem
Can you upload an picture of the radio wich is fitted to the radio now?
its same as the one in link
https://allegro.pl/oferta/radio-fiat-ducato-dotyk-14-735625821-7887731112
I had to go into the radio module and enable the navigation part of the radio as I had replaced the original and basic radio (no nav or CD) that comes with a Boxer and the the proxy alignment ran OK
Hop that works for you
Trev
Trev
abarthmultijet
Can you try this proxy?
Do you know how to edit and upload an custom proxy in the car?
yes i know , thx , i will try itabarthmultijet wrote: ↑25 Mar 2025, 21:03 Can you try this proxy?
What is the result please for your operation?
Pardul wrote: ↑26 Mar 2025, 20:33yes i know , thx , i will try itabarthmultijet wrote: ↑25 Mar 2025, 21:03 Can you try this proxy?
i made it without proxy setings oooOOoooo
As you can see you have to change byta 115 from 17 to 10Pardul wrote: ↑23 Mar 2025, 05:21 Hi
22.03.2025 19:17:14
FAILED TO EXECUTE
22.03.2025 19:25:38
VIN lock status:
