MES different ME7.9.10 and ME17.3
Posted: 15 Mar 2025, 18:43
I have a mix off some 1.4-16V turbo T-Jet applications in 2x Abarth, Tipo Bravo and Grande Punto.
Two Euro 6 and 3 Euro 5 ECUs.
The ME7.9.10 and ME17.6 engine us both same crank shaft cam shaft sensor.
The MES show connected to ME7.9.10 (Euro 5 type) the injection timing parameter a deg. Value. Perfect would be zero (timing between crank and camshaft sensor).
Same engine, just Me17.6 (Euro6) MES but you can’t offer/ or MES do not offer this parameter?
The ME17.6 is the newer generation and MES offer a larger selection of parameters, but for timing belt diagnosis parameter (injection timing) is gone or or is the name changed?
