alfa romeo tonale 1.6 support
bullone
Post by bullone »
Greetings..
I would like to ask for information ..
I'm about to buy an Alfa Romeo Tonale and looking at the compatibility of your program on the site, only the diagnosis of the 1.3 plug in and 1.5 Hibrid is diagnosed ..
I wondered why I don't see the 1.6 multijet on the vehicle list and if this motorization will be managed in the future
Thanks and I apologize for my English because I am using a translator.
chrener
Re: alfa romeo tonale 1.6 support
Post by chrener »
Hi!
Your engine is the same as in Tipo 500X Renegade Compass etc...
So connect via other type of car...
bullone
Post by bullone »
HI
I just bought the car and still not in my possession
I come from a Giulietta where it was enough to connect a simple elm
I don't know how protective sgw works and which cables or devices to use
Do you say that with access to other cars of the same group, is it possible to reset the service Odometer and DPF?
Thank you
abarthmultijet
Post by abarthmultijet »
bullone wrote: 02 Feb 2025, 21:23 HI
Thank you
Yes you need the find the right module at an different car, chrener has more experience
illiac4
Post by illiac4 »
But he will still need to bypass SGW which I have not seen anyone done it because it is in the board computer.
The only site that has some info is this one https://www.diamini.it/sgw.html
bullone
Post by bullone »
HI..
I saw .. Talk about these connections ... I think flying and vagus where they are connected ...
The tonal has the sgw integrated into the body computer. It is therefore not possible to use the Sgw bypass adapter.
The C-Can1 is located in the connector under the right-hand Battitacco. Can h pin 8 white-black, can l pin 18 black.
Now I wonder how Multiecuscan can connect to the petrol model .. not and specified but is on the list of supported cars
Alfa Romeo
Tonale
1.5 Hybrid Battery pack control (MHEV) |INFO|DTC|DTC EX|PRM| ELM
Continental GPEC4LM CF6D Injection (1.5 GSE MHEV) |INFO|DTC|PRM|ACT|ADJ| ELM
Hybrid control processor (MHEV) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Continental ABS MK C1 |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMA6
Service Interval Reset (965) |INFO|ADJ| ELM
Instrument Panel Bosch (965) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Body Computer Aptiv (965) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Alfa Romeo
Tonale
1.3 Plug-in Hybrid Battery pack control (PHEV) |INFO|DTC|DTC EX|PRM|ADJ| ELM
Continental GPEC4LM CF6D Injection (1.3 GSE PHEV) |INFO|DTC|PRM|ACT|ADJ| ELM
