Alfa Romeo Giulia Parking System upgrade
Dmitry674011
Post by Dmitry674011 »
Hi all!
I would like to retrofit AF Giulia with parking sensors. They don't come from the factory. I think, i need to buy both bumpers, sensors, a control unit and a light switch with a parking sensor button. Well, and the wiring harnesses. Does anyone know how to add a parking system to a proxy? Do I need to cut wires or change the BCM?
Re: Alfa Romeo Giulia Parking System upgrade
not sure if wiring is there when car comes without parking sensors. check in trunk below rear left tail light behind trim if there are 3 connectors for PDC module and below 3 fuse boxes below front right headlight for connector for front PDC sensors for front bumper. if those are present you'll need just wiring for front/rear PDC sensors in bumpers.
Dmitry674011
I looked. There are no connectors. But I'm more interested in how to programmatically add this option.
chrener
Post by chrener »
Hi!
Dont worry parking control module will be after retrofit automatically added into system an all you have to do is run proxi alignment procedure.
If you will do only rear sensors you wont need anything else, but if you will added also front sensors then change value on byte 118 to 10.
regards
