Will this cable work with Multiecuscan?
atikovi
Post by atikovi »
Will be using a Windows laptop. Have this cable I got years ago for some diagnostic program I've long forgotten about,
will it work and If not, what is recommended here? Will I also need a yellow adapter cable or bluetooth adapter. Working U.S. model Fiat.
abarthmultijet
Re: Will this cable work with Multiecuscan?
Post by abarthmultijet »
I highly doubt that this cable will work.
Get an Cantiecar or ELM cable, when you have a good adapter and connection between your car it is worth its weight in gold.
atikovi
Post by atikovi »
I also have a VAGCOM cable for VW/Audi and this cable for Ford/Mazda used with Forscan,
abarthmultijet
You can check what adapter works with your car here: https://www.multiecuscan.net/VehicleSupportCheck.aspx
