Maybe I need little bit explain why I'm asking for this particular safety functionalities. In my Lancia Delta (2011) I swaped original NavRadio unit with Android headunit (radio) but for this change it was needed to change configuration of my BCM unit (missing factory radio unit -->> wrong proxy alligement). For these changes I used paid version of AlfaOBD app which was worked expect one for me important detail
Some times ago I tried to restore my car BCM configuration to factory settings using oficial Examiner tool and ESS and HBA instantly start working again, but next I need again to deactivate my factory NavRadio unit due to my swap with Android headunit.
Do you somebody know when I again restore my BCM configuration to factory settings if I can used registered version of Multiecuscan to change my BCM configuration (swap Navradio) without affecting my factory safety functionalities ESS and HBA ?
What I already know is at least when I restore my BMC configuration to factory settings I can make a backup of this factory settings using custom PROXY configuration in Multiecuscan
Thank you
