Radio change help
Posted: 08 Jul 2024, 09:43
by Sikmariusik
Hy I changed on an alfa mito the radio unit with an android head unit with can adapter. Unfortunately the km started to flash after changing. I tried to disable the radio unit with multi ecu scan but I don't know how. I tried to do a proxy alignment but I receive an error on RNN module. Thank t
You in advance for any possible help
Alfa romeo mito 2010
1.4 turbo multiair 170 hp
Re: Radio change help
Posted: 13 Jul 2024, 14:53
by Sikmariusik
No help? :roll: :?:
Posted: 02 Sep 2024, 07:35
by Jordyw
Hi!
I had a mito from 2010 (QV).
I didnt have this problem because I was using an adapter that blocks this.
What you can try is disable the blue&me with ECUscan.
What you also can try is make from the 8 button steering wheel a 6 button steering wheel. This is also sometimes the issue.
