External Temperature in Doblo 119
Posted: 23 Apr 2024, 11:49
I try to activate dispplay external temperature on dasbord in fiat doblo. My dashboard have got this opction in technical specyfication. But when i try to activate it and make proxy i have this problem:
First, when i change value in ecternal temperature displayi have bug: "failed to execute: unsupported function error"
And when i try to execute proxy aligement procedure i have bug: Dashboard Node (IPC/NQS) FAILED! - Data out of range error:
Here the logs:
CAN CONFIGURATION DATA:
00 00 00 0B 00 00 00 0B 00 00 00 00 00 00 00 00
00 00 00 0B 00 00 00 09 00 00 00 0B 00 00 00 09 00 00 00 09
35 31 37 37 39 37 39 37 20 20 20 50 50 45 41 43 45 45 45 53 49 20 05 05 19 0B 00 00 00 09 00 00 00 81 C8 0D 01 04 0C 17 07 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
(Multiecuscan 5.2)
PROXI ALIGNMENT PROCEDURE
Zapis danych konfiguracyjnych CAN ...
Zapis do modułu: Body Computer Node (BCM/NBC) SUCCESS!
Zapis do modułu: Dashboard Node (IPC/NQS) FAILED! - Error: Data out of range error
WYKONANIE NIEUDANE
Dashboard Node (IPC/NQS) FAILED! - Error: data out of range error
Should I try expand custom proxy file with 00 bytes, but which byte support external temperature?
Thanks for help
Here the logs:
(Multiecuscan 5.2)
WYKONANIE NIEUDANE
Thanks for help
