Hi!
I own an Alfa Romeo Giulietta 2.0 JTDm 16V (2011).
The problem is as follows:
No bluetooth, no CD, no usb working. In reality/physically, the Blue&Me module is present and also connected, but Multiecuscan does not detect the Convergence Telematic module. I performed several PROXI Alignments, but there is a conflict with the Convergence Telematic module and it is as if it does not exist - it has disappeared.
I searched this forum for a solution to my problem, but unfortunately I couldn't or couldn't find the right solution.
I really want Blue&Me to work. I suspect that the Blue&Me module is broken, but before I buy it, I would also like to hear the advice of others...Should I replace a module? Or can the Multiecuscan software change the parameters? I need some good advice!!
(I use the registered Multiecuscan 5.1 MULTIPLEXED software with CANtieCAR interface for scanning.)
I'll add a log file to my post and also some Multiecuscan screenshots.
With good wishes,
Riho
CAN CONFIGURATION DATA:
4F 04 00 05 40 00 00 00 4F 04 00 05 40 00 00 00 00 04 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 04 00 05 40 00 00 00 09 04 00 04 42 00 00 00 4F 04 00 05 40 00 00 00 09 04 00 04 42 00 00 00 09 04 00 04 40 00 00 00
30 34 31 39 31 30 30 35 35 37 30 4F 55 54 50 55 54 2D 4A 49 54 20 11 04 14 4F 04 00 05 40 00 00 00 09 04 00 04 42 00 00 00 C7 C5 51 07 8F 00 3C 20 B8 10 00 16 00 07 07 9C 06 2B 03 46 00 00 02 00 3A 51 0A 7C 00 00 00 00 09 01 00 00 00 37 01 E1 01 38 00 20 00 00 00 00 06 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
Convergence Telematic Node (CTM)
(Multiecuscan 5.2)
20.04.2024 20:33:56
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
Convergence Telematic Node (CTM): -
Receiver Radio/Radio Navigator Node (NRR/RMN): EOL Ok
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Convergence Telematic Node (CTM) FAILED! - Timeout error
Writing to module: Receiver Radio/Radio Navigator Node (NRR/RMN) SUCCESS!
FAILED TO EXECUTE
https://drive.google.com/file/d/1T0WMyhLOuEk1p1CT_X73zHMjRN0gyyn4/view?usp=sharing
https://drive.google.com/file/d/1c3Mc2i9LUopC3o-TrCvD2OiDo2i24dTI/view?usp=sharing
https://drive.google.com/file/d/19UVefzwQrW1Z_aaZ4Up1Ecus5s0_wpxT/view?usp=sharing
https://drive.google.com/file/d/1vpt8pB8AnRcsPLFTcKbGSIwIK_XQbAk3/view?usp=sharing
https://drive.google.com/file/d/1COe45_FaIr-uSZn_XnIIpx_hmYekcpNR/view?usp=sharing
PROBLEM SOLVED! Alfa Romeo Giulietta Blue&Me problem
Re: PROBLEM SOLVED! Alfa Romeo Giulietta Blue&Me problem
I have exactly the same model Giulietta and the odometer started blinking 2 weeks ago for no apparent reason.
I bought this from amazon;
OBDResource OBD2 Scanner USB ELMconfig FoCCCus Diagnostic Tool with MS-Can/HS-Can Switch for Ford Mazda for Windows
Alchiauto Diagnostic Cable OBD2 ECU Yellow A3 for Fiat ECUScan Multi Scan
because I thought a proxi aligment would fix the issue, but the proxi aligment execute fails to finish giving your exact same error about the Convergenge Telematic Node (the blue&me module).
Could you share what fixed this for you?
