OBD II Scan tool bluetooth and this multiecuscan
Posted: 04 Jun 2010, 18:30
by Zwiebel
Hi!
I'm new in this program use. I have 1 cable OBD II scanner, and 1 bluetooth OBD scanner. I want to use them, but with this program, only the cable scanner is good. When I connect the bluetooth to my computer, everything is good, but when I'm go to the program and want to connect, I have an error message, with timeout. I tried every speed, and COM. My program write in settings to test, Command: ATZ and error here too... Please, if you can, help for me :cry:
Re: OBD II Scan tool bluetooth and this multiecuscan
Posted: 05 Jun 2010, 10:49
by EnIgMa
does windows recognize it?
can you view a kind of bluetooth devices list?
if yes, check the com port and speed, THEN try to use it with fiat ecu scan...
what's your OS?
Posted: 05 Jun 2010, 12:23
by Zwiebel
I use XP with Service Pack 3. I see the OBD in my bluetooth devices, and it's write connected. I tried COM6 and COM7 Port with all speeds, but at the Test function it writes error too.
Posted: 11 Jun 2010, 16:55
by DeXa
I am also having problems connecting with Bluetooth ELM327 v 1.3a. I get timeout errors. I have tested all sort of settings with no luck at all. When I use hyper terminal or putty to open the comport directly everything is fine and I have no timeouts and disconnects I am able to send commands to the interface but with FES I can't.
Posted: 13 Jun 2010, 21:32
by EnIgMa
taht's strange,,,did you guys try a previous version?
