Page 93 of 257
Posted: 10 Sep 2013, 18:05
marinozacc wrote:
Alfaeddy wrote:Hello
What Punto you?
What Year?
For the models from year 99
can the remote control via CAN bus are programmed.
http://www.ebay.de/itm/260754573911?_tr ... EBIDX%3AIT
Or do you want to program the immobilizer?
This is only possible with AlfaOBD
yes i want to encoding the trasponder
it's possible with multi ecuscan too?
thanks for the link , but i'm confused .. autodia327 is the same elm327?
and it will work on ford fiesta (2006) and alfa romeo 147 (2000)??
thank you a lot!!
edit: for example this
http://www.ebay.it/itm/V1-5-ELM327-OBD- ... 48a&_uhb=1
read the same protocol of autodia327.. change anything?
Hello Marinozacc
No, this interface will not work.
because it has this bridge resistor with the Multiecuscan has problems.
The interface in my link has been so transformed by the seller, according to my information so that it works with Multiecuscan.
Most others need to be changed, as described in this thread.
With Multiecuscan you can not store a transponder.
I think this goes on with AlfaOBD Punto not, but I'm not sure
for my Alfa 156 I can do with AlfaOBD
Posted: 10 Sep 2013, 18:10
xarik wrote:
alfa156sarajevo wrote:@ xarik & @ Alfaeddy
As I can see on xarix photo is ELM 327 version 1.2 - at least that is written on the board.
As far as I know in that version is not possible to access CAN network.
Version v1.3 and higher can work with CAN network...
Alfaeddy correct me if I am wrong... :roll:
I have the yellow, green and red cables.
Hello xarik
As you use the adapter, unfortunately, nothing.
How Alfa156sarajevo writes properly, thanks again
your v1.2 interface can not read CAN bus.
Your ECU, ABS and steering goes, sure to read it
For CAN bus protocols you need another ELM Interface
Posted: 10 Sep 2013, 19:21
by marinozacc
but if I remove resistor will work.. right?
Posted: 10 Sep 2013, 19:56
by xarik
Ok Thx
With this interface it's good ?
http://www.obdii.fr/elm327-bluetooth-ca ... ol-86.html
Posted: 10 Sep 2013, 20:46
marinozacc wrote:but if I remove resistor will work.. right?
Right :D
Posted: 10 Sep 2013, 20:49
xarik wrote:Ok Thx
Hello Xarik
Yes you can use this interface.
Probably but the bridge resistor must be removed.
Posted: 10 Sep 2013, 22:37
by xarik
Alfaeddy wrote:
xarik wrote:Ok Thx
Hello Xarik
Thank you very much of your help
Posted: 11 Sep 2013, 10:20
by marinozacc
why the mini elm 327 hasn't work?
Posted: 11 Sep 2013, 19:53
marinozacc wrote:why the mini elm 327 hasn't work?
hi
Yeah right, because it has to be removed then yes this resistor.
Posted: 20 Sep 2013, 09:58
by locdogbg
Alfaeddy wrote:Hello Skorchichko
Remove the highlighted in yellow frame resistor (R04)
and your interface can also read the other controllers
Thanks, after removing "121" resistor on R4 and CAN is working fine :)
I still can't understand why the thing is there, it's a chineese conspiration.
