Thanks for the information supplied.
Similar issues as others replaced stereo with android head unit. After proxy alignment
4F 80 00 04 10 00 00 00 4F 80 00 04 10 00 00 00 01 00 00 00 10 00 00 00 01 00 00 00 10 00 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 4F 80 00 04 10 00 00 00 09 00 00 04 10 00
33 32 31 35 30 30 31 32 32 39 39 4F 55 54 50 55 54 44 4A 49 54 20 14 11 13
4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 13 C2 71 06 F4 00 1C 00 AA
00 00 26 00 01 00 94 06 01 01 00 00 00 00 10 7A 41 0A 0C 0D 00 80 00 23 00
00 00 00 31 05 11 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Airbag Node (NAB/ORC)
(Multiecuscan 5.1)
02/05/2024 10:46:16
Fiat 500 1.2 8V
WARNING This vehicle is properly configured. PROXI Alignment is not needed!
but
PROXI ALIGNMENT PROCEDURE
Writing to module Body Computer Node (BCM/NBC) SUCCESS!
Writing to module Dashboard Node (IPC/NQS) SUCCESS!
Writing to module Airbag Node (NAB/ORC) SUCCESS!
Writing to module Entertainment Telematic Node (ETM) FAILED! - Timeout error
FAILED TO EXECUTE
and the custom PROXI differs from the above starting 33 32 etc (3rd line down)?
Any help would be much appreciated.
(Multiecuscan 5.1)
02/05/2024 10:46:16
Fiat 500 1.2 8V
but
FAILED TO EXECUTE
eddyribeiro
Good morning my friends! I'm from Brazil and I need help if you can help me. I replaced my radio with another one, my car is a 2016 Fiat Uno, I think the module should be similar to a Fiat 500 Chrysler, Cherokee Jeep Renagade. I installed it in the car and the steering wheel controls worked, it updated the time based on the time on the vehicle's dashboard. But Android Auto doesn't work, nor does the music track appear on the dashboard. Your proxy bytes reach 136. Can you help me? I can send more details and sorry for my English
my proxy original 136 bytes: 33 33 31 39 35 31 35 32 33 37 36 4F 55 54 50 55 54 44 4A 49 54 20 14 08 20 4B 01 00 04 00 00 00 00 00 00 00 00 00 00 00 00 4B 01 00 04 00 00 00 00 00 00 00 00 00 00 00 00 10 20 20 07 80 00 07 1C 00 26 07 07 3B 00 20 06 91 14 70 01 10 05 00 14 00 00 00 00 00 01 00 00 01 00 00 00 80 00 00 00 00 00 00 01 00 01 01 34 00 0F 00 80 00 00 00 01 00 00 00 00 00 01 00 80 00 00 00 0F 00 00 49 00 00 00 00 00 00 00 00
Old radio:
Old radio:
Old radio
New radio:
New radio:
Error Mes:
Old radio:
Old radio:
Old radio
New radio:
New radio:
Error Mes:
Hi, I'm a new Abarth owner, and have upgraded the head unit to a 7", and have had the expected proxi alignment issue, I have been using this forum, and an installation guide on line, and the proxi alignment has reset the flashing odometer, but the odometer is now showing in Km, and the speedo is now in Km/h.......Could anybody offer any advice as to why this has happened and how it can be reset to miles and miles/hr?
Thanks in advance, any help appreciated.
Steve
Steve
Should be able to go into the vehicle settings on the software and change the units, if it's not done on the dash itself like the earlier models. Often find they revert to kilometres after a proxi and need changing back to milesJanste wrote: ↑22 May 2024, 19:34 Hi, I'm a new Abarth owner, and have upgraded the head unit to a 7", and have had the expected proxi alignment issue, I have been using this forum, and an installation guide on line, and the proxi alignment has reset the flashing odometer, but the odometer is now showing in Km, and the speedo is now in Km/h.......Could anybody offer any advice as to why this has happened and how it can be reset to miles and miles/hr?
Steve
Thanks Timbo 127, I reset it in the settings on the head unit last night, and earlier this afternoon, I had a tweak in the custom proxi, and found that byte 53 was originally 26, the data I'd be given wasn't from the UK, and was 16.Timbo172 wrote: ↑22 May 2024, 23:02Should be able to go into the vehicle settings on the software and change the units, if it's not done on the dash itself like the earlier models. Often find they revert to kilometres after a proxi and need changing back to milesJanste wrote: ↑22 May 2024, 19:34 Hi, I'm a new Abarth owner, and have upgraded the head unit to a 7", and have had the expected proxi alignment issue, I have been using this forum, and an installation guide on line, and the proxi alignment has reset the flashing odometer, but the odometer is now showing in Km, and the speedo is now in Km/h.......Could anybody offer any advice as to why this has happened and how it can be reset to miles and miles/hr?
Steve
All back to where it should be, and everything is working as it should.
Cheers
Steve
hi, after change my uconnect from 5 to 7, my beats audio system rear speaker and subwoofer stop working.
Now i dont know if it can be a problem whit the proxy alignment or somenthing else.
Could anyone hel me?
Bossie_500
I bought a 2017 Fiat 500c Sport, this Fiat has a Uconnect 7. I hope this has carplay, and I have done a proxy alignment. Only I still don't have carplay, the car is a Dutch car and I also live in the Netherlands.
Below is the can configuration data
CAN CONFIGURATION DATA:
4F 80 00 05 10 00 00 00 4F 80 00 05 10 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 33 32 31 35 30 30 31 39 37 35 39 4F 55 54 50 55 54 44 4A 49 54 20 16 06 29
4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 42 73 06 FE 20 1C C0 00
00 00 16 00 01 00 94 06 01 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00
00 00 00 31 05 68 00 08 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 8C 00 94 08 52 00 04 93 02 00 20 80 00 00 44 00 D5 00 0F
00 00 00 00 01 00 E0 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00
00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer (BCM/NBC)
Motorcontrole (ECM/NCM)
Elektrische besturing (EPS/NGE)
Instrumentenpaneel (IPC/NQS)
Remsysteem (ABS/BSM/NFR)
Knooppunt slingering/zijdel.acceleratie (NYL)
Knooppunt pakeersensor (PAM/NSP)
Knooppunt Airbag (NAB/ORC)
(Multiecuscan 5.2)
26-7-2024 12:47:07
Fiat 500 0.9 Turbo TwinAir
Body Computer (BCM/NBC) EOL Ok
Motorcontrole (ECM/NCM) Ok
Elektrische besturing (EPS/NGE) Ok
Instrumentenpaneel (IPC/NQS) EOL Ok
Remsysteem (ABS/BSM/NFR) Ok
Knooppunt slingering/zijdel.acceleratie (NYL) Ok
Knooppunt pakeersensor (PAM/NSP) Ok
Knooppunt Airbag (NAB/ORC) EOL Ok
Entertainment Telematic Node (ETM) EOL Ok
WAARSCHUWING This vehicle is properly configured. PROXI Alignment is not needed!
CUSTOM PROXI NEW DATA:
33 32 31 35 30 30 31 39 37 35 39 4F 55 54 50 55 54 44 4A 49 54 20 16 06 29 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 EXECUTING ADJUSTMENT...
PROCEDURE UITLIJNING PROXI
Writing to module Body Computer (BCM/NBC) SUCCESS!
Writing to module Instrumentenpaneel (IPC/NQS) SUCCESS!
Writing to module Knooppunt Airbag (NAB/ORC) SUCCESS!
Writing to module Entertainment Telematic Node (ETM) SUCCESS!
UITGEVOERD
I have the uconnect radio below
(Multiecuscan 5.2)
26-7-2024 12:35:56
Uconnect Radio/Nav 7"
ISO code: 00 24 70 55 15
Code V.I.N.: ZFA3120000J636696
Serienummer ECU: TD3401816032010
Tekeningnummer FIAT: 735637227
Nummer HW: F.EU.D3.V23
Versie Hw: 23
Nummer SW: 21.01.14.01
Versie SW: 2101
Nummer homologatie: 031634
Werkingstijd (EEPROM): 12294
Bedrijfsduur: 12299
Teller Key-On: 6230
VIN lock status:
PROXI configuration write counter:
READING ERROR CODES:
Geen fout codes
Does anyone have an idea what I'm doing wrong?
(Multiecuscan 5.2)
26-7-2024 12:47:07
UITGEVOERD
(Multiecuscan 5.2)
26-7-2024 12:35:56
Versie Hw: 23
Versie SW: 2101
Bedrijfsduur: 12299
Teller Key-On: 6230
VIN lock status:
Geen fout codes
Hi Im Roa from Mexico and i try to get the correct Proxy Alingment for my Abarth 2019. Upgrade the Uconnect 5 (maps, rear camera, Subwoofer and Amplifer in the trunk) to Uconnect 7 312E vp2 (ECE Dab NAV) Date 07/03/2024 SW-V 23.03.67.12 HW-V F.EU.D8.V28abarthmultijet wrote: ↑04 Apr 2022, 21:15 If this was your current code:
33 32 31 35 30 30 31 34 31 35 30 4F 55 54 50 55 54 44 4A 49 54 20 15 07 11 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 42 71 06 FE 20 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 18 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 93 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 E0 01
Try this one:
33 32 31 35 30 30 31 34 31 35 30 4F 55 54 50 55 54 44 4A 49 54 20 15 07 11 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 42 71 06 FE 20 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 18 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 93 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 E0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
This is my backup:
31 39 31 37 31 36 35 36 32 30 30 31 32 33 34 35 36 37 38 39 30 20 19 02 27 4F 84 00 04 03 00 00 00 09 00 00 00 03 00 00 00 81 C0 4D 06 F4 40 01 70 0A 01 00 87 00 09 00 94 00 00 02 00 01 00 30 60 00 00 00 00 00 00 00 00 27 00 00 00 00 31 06 B1 01
abarthmultijet
Roameroll wrote: ↑26 Aug 2024, 19:36Hi Im Roa from Mexico and i try to get the correct Proxy Alingment for my Abarth 2019. Upgrade the Uconnect 5 (maps, rear camera, Subwoofer and Amplifer in the trunk) to Uconnect 7 312E vp2 (ECE Dab NAV) Date 07/03/2024 SW-V 23.03.67.12 HW-V F.EU.D8.V28abarthmultijet wrote: ↑04 Apr 2022, 21:15 If this was your current code:
Try this one:
This is my backup:
I don't think it is your correct proxy code. Go to the proxy allignment tab on multi ecu scan and press control+alt+c, then copy paste that code here
Inquiry from Japan
The 2017 European FIAT500 has been changed from 5 inches to 7 inches UCONNECT.
I adjusted the custom proxy alignment, but Apple CarPlay does not work.
Please tell me the correct proxy.
Kind regards
Below is the current proxy.
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 70 00 81 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Inquiry from Japan
Kind regards
