Page 9 of 13
Posted: 22 Nov 2023, 06:29
by Andrea11uno
abarthmultijet wrote: 06 Apr 2022, 20:26 No problem, hope you are happy with it.
Try to plug in your phone, this code supports apple carplay/ android auto. If it doesn't work i know how to activate it. Send me a PM!
Hi, how can i contact you to activate CarPlay? I need help
Posted: 22 Nov 2023, 06:38
by Andrea11uno
Qualcuno conosce la procedura per attivare CarPlay?
Does anyone know the procedure to activate CarPlay?
Posted: 23 Dec 2023, 12:34
by Timbo172
Anybody worked out whether the G-Meter can be enabled on a retrofit TFT conversion? Or does the BCM/sensor need to be a later version for it to work?
Was hoping it would be possible to change the HEX.
Also enabling the throttle gauge on the TFT dash?
Posted: 12 Jan 2024, 14:10
by JassyIvy
josesales wrote: 07 Nov 2023, 21:56 Hello
I replace original radio on my Fiat 500 year 2016 for a 7" Uconnect.
Now I have DTC DAB aereal antena.
When I try align proxy I got error.
Can someone help me with proxy manual configuration to fix this please?
My log:
CAN CONFIGURATION DATA:
4F <a href="tel:80 00 05 00 00 00 00">80 00 05 00 00 00 00</a> 4F <a href="tel:80 00 05 10 00 00 00">80 00 05 10 00 00 00</a> <a href="tel:09 00 00 01 10 00 00">09 00 00 01 10 00 00</a> <a href="tel:00 01 00 00 00 10 00">00 01 00 00 00 10 00</a> <a href="tel:00 00 00 00 00 00 00">00 00 00 00 00 00 00</a> 00 00 00
4F <a href="tel:80 00 05 00 00 00 00">80 00 05 00 00 00 00</a> <a href="tel:09 00 00 04 00 00 00">09 00 00 04 00 00 00</a> 00 4F <a href="tel:80 00 05 10 00 00 00">80 00 05 10 00 00 00</a> <a href="tel:09 00 00 04 10 00 00">09 00 00 04 10 00 00</a> <a href="tel:00 09 00 00 04 00 00">00 09 00 00 04 00 00</a> 00 00
<a href="tel:33 32 31 35 30 30 31">33 32 31 35 30 30 31</a> <a href="tel:38 33 30 37">38 33 30 37</a> 4F <a href="tel:55 54 50 55 54 44">55 54 50 55 54 44</a> 4A <a href="tel:49 54 20 16 04 06">49 54 20 16 04 06</a> 4F <a href="tel:80 00 05 00 00 00 00">80 00 05 00 00 00 00</a> <a href="tel:09 00 00 04 00 00 00">09 00 00 04 00 00 00</a> 00 01 C2 73 06 FE 00 1C C0 <a href="tel:00 00 00 16 00 01 00">00 00 00 16 00 01 00</a> <a href="tel:94 06 41 01 00 40 00">94 06 41 01 00 40 00</a> <a href="tel:00 00 75 41">00 00 75 41</a> 0A 0C 0D 01 80 2E <a href="tel:24 00 00 00 00 31 05">24 00 00 00 00 31 05</a> <a href="tel:11 00 00 00 04 00 00">11 00 00 00 04 00 00</a> <a href="tel:00 00 00 00 00 00 00">00 00 00 00 00 00 00</a> <a href="tel:00 00 00 00 00 00 00">00 00 00 00 00 00 00</a> <a href="tel:00 00 00 00 00">00 00 00 00 00</a> 9E <a href="tel:00 94 00 22 00 04 88 00 00">00 94 00 22 00 04 88 00 00</a> <a href="tel:20 80 00 00 40 00 01">20 80 00 00 40 00 01</a> 00 0F <a href="tel:00 00 00 00 01 00 40">00 00 00 00 01 00 40</a> <a href="tel:01 00 00 00 00 00 00">01 00 00 00 00 00 00</a> <a href="tel:00 00 00 00 00 00 00">00 00 00 00 00 00 00</a> 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Side Acceleration / Yaw Node (NYL)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
(Multiecuscan 4.7R3)
07-11-2023 11:17:17
Fiat 500 1.4 16V T-Jet/MultiAir
Side Acceleration / Yaw Node (NYL): Ok
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
Entertainment Telematic Node (ETM): Added / EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Request out of range error
| Byte 148: 00->1C
FAILED TO EXECUTE
Byte 148 must be changed from 00 to 1C in the Custom Proxi window then Execute a Proxi Alignment.
The error is highlighting a setting or feature on the new head unit that is available but not switched on.
This is an excellent a knowledge article that explains how to change, troubleshoot and fix Proxi code errors.
https://vk2.net/articles/Abarth-UConnect%205-to-7-Upgrade
Posted: 10 Feb 2024, 18:42
by theGman
Hi everyone, I have a huge problem. I was using proxi alignment to check/enable carplay on my Uconnect 5". I made changes to bytes 148 and 157. No my car is completly dead. I tried to do a MES scan before it died. And it said too many modules disabled. Is it possible to reset the BCM? Or does it need to be done by a garage? Thanks.
EDIT: My problem was the battery was drained, 10.6v, therefore not enough voltage for various modules giving me multiple errors. Battery replaced and back up and running. Still don't have Carplay :(
Posted: 10 Feb 2024, 19:42
by theGman
Slayaz wrote: 22 Sep 2023, 16:03 HELP! I've just broken my car....
ALl i was trying to do was acrivate carplay!
I ffel sick
Hey Slayez I've just done the same trying to activate carplay. How did you get BCM recovered? My car is completely dead. :(
Fiat 500 replace BCM possible with Multiecuscan?
Posted: 14 Feb 2024, 21:36
by GeorgeDuh
Is it possible to replace the Body Control Module (BCM) in a Fiat 500 using Multiecuscan software, and if so, what are the steps involved in the process?
Posted: 18 Mar 2024, 15:41
by grun500
Thanks for all the info.
As I understand the old types Fiat 500 have 87 bytes
The newer types have 157 bytes?
is there any overview regarding what Byte has what options?
Posted: 21 Mar 2024, 16:51
by Dashcoder
abarthmultijet wrote: 29 Mar 2022, 16:50 Hello MichL,
I have send you a private message.
Hello my friend ,
I changed the radio on my Fiat 500 , I try to do proxy alignement but it failed , can you help me with good coding please . Thank you so much 🙏🙏
33 32 31 35 30 30 31 39 34 33 39 4F 55 54 50 55 54 44 4A 49 54 20 16 06 18 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 75 06 FE 00 1C C0 C0 10 00 16 00 01 00 94 06 01 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 B7 00 0F 00 00 00 80 05 00 E0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Structure / BCM (Body Computer Module)
Body Computer Delphi (312)
Code ISO: 00 00 60 15 14
Code V.I.N.: ZFA3120000JA39948
Numéro HW: 0312N6E4101 - Ver: 01
Numéro SW: 28626565 - Ver: 1412
Errors found:
B10AA-4A - Contrôle configuration PROXI - Incorrect component installed
Posted: 28 Apr 2024, 23:22
by xav50
hello, I am in the process of improving a Fiat Abarth 500 for my daughter, it is from 2008 and I am rejuvenating it with 2016 accessories, does anyone have a description of all the bytes (example 65 tft mode etc. ..), so that I can intervene on several elements, such as the turbo gauge, formerly shift up, now sport, the android car radio which flashes the mileage etc., thank you
French vehicle 😉
