Hi, how can i contact you to activate CarPlay? I need helpabarthmultijet wrote: ↑06 Apr 2022, 20:26 No problem, hope you are happy with it.
Try to plug in your phone, this code supports apple carplay/ android auto. If it doesn't work i know how to activate it. Send me a PM!
Qualcuno conosce la procedura per attivare CarPlay?
Does anyone know the procedure to activate CarPlay?
Anybody worked out whether the G-Meter can be enabled on a retrofit TFT conversion? Or does the BCM/sensor need to be a later version for it to work?
Was hoping it would be possible to change the HEX.
Also enabling the throttle gauge on the TFT dash?
Byte 148 must be changed from 00 to 1C in the Custom Proxi window then Execute a Proxi Alignment.josesales wrote: ↑07 Nov 2023, 21:56 Hello
I replace original radio on my Fiat 500 year 2016 for a 7" Uconnect.
Now I have DTC DAB aereal antena.
When I try align proxy I got error.
Can someone help me with proxy manual configuration to fix this please?
My log:
CAN CONFIGURATION DATA:
4F <a href="tel:80 00 05 00 00 00 00">80 00 05 00 00 00 00</a> 4F <a href="tel:80 00 05 10 00 00 00">80 00 05 10 00 00 00</a> <a href="tel:09 00 00 01 10 00 00">09 00 00 01 10 00 00</a> <a href="tel:00 01 00 00 00 10 00">00 01 00 00 00 10 00</a> <a href="tel:00 00 00 00 00 00 00">00 00 00 00 00 00 00</a> 00 00 00
4F <a href="tel:80 00 05 00 00 00 00">80 00 05 00 00 00 00</a> <a href="tel:09 00 00 04 00 00 00">09 00 00 04 00 00 00</a> 00 4F <a href="tel:80 00 05 10 00 00 00">80 00 05 10 00 00 00</a> <a href="tel:09 00 00 04 10 00 00">09 00 00 04 10 00 00</a> <a href="tel:00 09 00 00 04 00 00">00 09 00 00 04 00 00</a> 00 00
<a href="tel:33 32 31 35 30 30 31">33 32 31 35 30 30 31</a> <a href="tel:38 33 30 37">38 33 30 37</a> 4F <a href="tel:55 54 50 55 54 44">55 54 50 55 54 44</a> 4A <a href="tel:49 54 20 16 04 06">49 54 20 16 04 06</a> 4F <a href="tel:80 00 05 00 00 00 00">80 00 05 00 00 00 00</a> <a href="tel:09 00 00 04 00 00 00">09 00 00 04 00 00 00</a> 00 01 C2 73 06 FE 00 1C C0 <a href="tel:00 00 00 16 00 01 00">00 00 00 16 00 01 00</a> <a href="tel:94 06 41 01 00 40 00">94 06 41 01 00 40 00</a> <a href="tel:00 00 75 41">00 00 75 41</a> 0A 0C 0D 01 80 2E <a href="tel:24 00 00 00 00 31 05">24 00 00 00 00 31 05</a> <a href="tel:11 00 00 00 04 00 00">11 00 00 00 04 00 00</a> <a href="tel:00 00 00 00 00 00 00">00 00 00 00 00 00 00</a> <a href="tel:00 00 00 00 00 00 00">00 00 00 00 00 00 00</a> <a href="tel:00 00 00 00 00">00 00 00 00 00</a> 9E <a href="tel:00 94 00 22 00 04 88 00 00">00 94 00 22 00 04 88 00 00</a> <a href="tel:20 80 00 00 40 00 01">20 80 00 00 40 00 01</a> 00 0F <a href="tel:00 00 00 00 01 00 40">00 00 00 00 01 00 40</a> <a href="tel:01 00 00 00 00 00 00">01 00 00 00 00 00 00</a> <a href="tel:00 00 00 00 00 00 00">00 00 00 00 00 00 00</a> 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
(Multiecuscan 4.7R3)
07-11-2023 11:17:17
Fiat 500 1.4 16V T-Jet/MultiAir
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
Entertainment Telematic Node (ETM): Added / EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Request out of range error
| Byte 148: 00->1C
FAILED TO EXECUTE
The error is highlighting a setting or feature on the new head unit that is available but not switched on.
This is an excellent a knowledge article that explains how to change, troubleshoot and fix Proxi code errors.
https://vk2.net/articles/Abarth-UConnect%205-to-7-Upgrade
Hi everyone, I have a huge problem. I was using proxi alignment to check/enable carplay on my Uconnect 5". I made changes to bytes 148 and 157. No my car is completly dead. I tried to do a MES scan before it died. And it said too many modules disabled. Is it possible to reset the BCM? Or does it need to be done by a garage? Thanks.
EDIT: My problem was the battery was drained, 10.6v, therefore not enough voltage for various modules giving me multiple errors. Battery replaced and back up and running. Still don't have Carplay
Fiat 500 replace BCM possible with Multiecuscan?
Is it possible to replace the Body Control Module (BCM) in a Fiat 500 using Multiecuscan software, and if so, what are the steps involved in the process?
Thanks for all the info.
As I understand the old types Fiat 500 have 87 bytes
The newer types have 157 bytes?
is there any overview regarding what Byte has what options?
Hello my friend ,
I changed the radio on my Fiat 500 , I try to do proxy alignement but it failed , can you help me with good coding please . Thank you so much
33 32 31 35 30 30 31 39 34 33 39 4F 55 54 50 55 54 44 4A 49 54 20 16 06 18 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 75 06 FE 00 1C C0 C0 10 00 16 00 01 00 94 06 01 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 B7 00 0F 00 00 00 80 05 00 E0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Structure / BCM (Body Computer Module)
Body Computer Delphi (312)
Code ISO: 00 00 60 15 14
Code V.I.N.: ZFA3120000JA39948
Numéro HW: 0312N6E4101 - Ver: 01
Numéro SW: 28626565 - Ver: 1412
Errors found:
B10AA-4A - Contrôle configuration PROXI - Incorrect component installed
hello, I am in the process of improving a Fiat Abarth 500 for my daughter, it is from 2008 and I am rejuvenating it with 2016 accessories, does anyone have a description of all the bytes (example 65 tft mode etc. ..), so that I can intervene on several elements, such as the turbo gauge, formerly shift up, now sport, the android car radio which flashes the mileage etc., thank you
French vehicle
French vehicle
