Hi eddyshow
Which vehicle you would like to read it?
According to your description, it may be just this problem resistor
This Wifi ELM interface I do not know yet whether it is the resistance of R04 in your ELM I can not say
Do something, please make a picture (with Macro) from the board
I can tell you more about this
The user Alfa156sarajevo also has problems with the wifi ELM
although he has a resistor has remove from board
eddyshow
Post by eddyshow »
the vehicle is a 2003 fiat punto multijet.
I attach the picture as soon as possible
The user Alfa156sarajevo as solved?
As far as I know he has not yet found a solution
But he says that he only has a problem with Multiecuscan
With AlfaOBD and ScanMaster should be Wifi ELM works well
But your problem seems that the CAN bus problem in this thread
will be described.
eddyshow
Post by eddyshow »
I include photos of the front and back of the interface circuit elm327 wifi.
I hope in you for the solution.
Hello eddyshow
Remove the resistor in the red frame (R04) and your ELM can read the CAN Bus Protokoll
Wifi ELM markiert.jpg (485.33 KiB) Viewed 9056 times
swatchlu
Post by swatchlu »
Hi Eddy,
I have ELM 327 V1.5a. I can only read using multiescan, electric steering, gearbox and engine.
I cannot read body, dashboard,abs service and climate control.
What do I need to do on this ELM327 1.5a, in order for it to read the rest of the modules? What do I need to remove?
my ride - Fiat 2006 Grande Punto 1.4 8V.
Thanks...
ELM 327 V15a.jpg (449.58 KiB) Viewed 9050 times
ELM 327 V15a 1.jpg (475.1 KiB) Viewed 9050 times
Hi swatchlu
Remove the resistor in the red Frame ( R04) and you can read also CAN Bus with your ELM Interface
ELM 327 V15a 1 markiert.jpg (103.16 KiB) Viewed 9049 times
swatchlu
Post by swatchlu »
Alfaeddy wrote:Hi swatchlu
Hi Eddy,
Thank you!
if I remove R04, as mentioned. Will affect the ones that I already can read?
No, it changed this what you read previously could not.
Multiecuscan has read these interface problems with the CAN bus
By removing the resistor we the only possible CAN bus the other protocols are not affected
eddyshow wrote:the vehicle is a 2003 fiat punto multijet.
No, still no solution for MES and WiFi.
If somebody else is thinking to use elm wifi and MES I would not advise you to buy it.
Elm WiFI works with AOBD and SM but not with MES. :(
