Again, if you can not connect to your ECU
has nothing nothing nothing to do with the resistors described here in this thread!!
At your Alfa 159!
Flama79
Post by Flama79 »
Hi!
i would like to thank anyone that contribute to this thread, and especially Alfaeddy for his precious help.
reading this thread I was able to get my interface working flawlessly.
My interface has the same pcb (there is written 2012-02-06 b1uwOBD V1.6 ) as betyargabor (page 36) and fiatbravoemotion (page 38), but it's a USB one not a bluetooth one.
Removed the R04 and it works!
The only difference I've found with other similar interfaces is that it has a Silicon labs CP2102 chip instead of the usual FTDI chip.
I've found the driver here: http://www.silabs.com/products/mcu/Page ... ivers.aspx
PS.: I'm sorry for my bad english
Hello Flame79
Thank you for your contribution
and above all that you read in previous posts where ever the problem is
The driver problem I had to talk to a user of the
http://www.alfa-romeo-portal.de/arcommu ... -blog.html
He has had the same problem with his laptop and with the daughters laptop
but it works. Then he inquired about why Google is so
and of specific part of the USB chip does not come with the usual drivers cope
But in the meantime I had already forgotten
I get older :twisted:
Thank you for your driver link
lolo85v
Post by lolo85v »
Hello thus I have to command(order) elm327 he(it) works very well thank you eddy
http://cgi.ebay.fr/Autodia-E327-CAN-Bus ... 3cb62f0a57
Hello Lolo85v
Nice that it works now! :D
It could then only be a problem on the interface
Hi Eddy man,
Few questions for you:
- do you have experience regarding ELM 327 WiFi OBD interface?
- did you manage it to work with MES?
I have clone elmWIFIobd and it works with AOBD but not with MES.
In test mode everything is perfect but in real connection does not work... :roll:
Hi Alfa156sarajevo :)
No I have not yet tested WiFi interface and can not say anything to
But was already thinking to buy me one, in order to test
Which WiFi Elm you?
I have elm 327 wifi clone. Had problem with r4 resistor.
Removed it and it is working fine with AOBD and ScanMaster 2.1.
It works only in test mode with MES. It is not working in real conection.
I guess it is a bug in MES. :(
Hi alfa156sarajevo
I think so too :?
eddyshow
Post by eddyshow »
Hello everyone. is the first time I write in this forum and I can tell you that I have just purchased the interface elm327 with wifi v1.5 MUS I can only connect to the engine control unit. gives me problems with the connection with the other control as the body or resetting service. I read that I have to remove the resistor R04 to operate the interface. sure which is the exact procedure? sorry for my english
