ELIO65
Post by ELIO65 »
Eddy... Now?
Hi Elio65
Your pictures are not better :cry:
Why did you use a photo flash? No Flash please
Why do you take such great size (3250 x 2600)
800 x 600 is quite enough
A large size (pixels) is better
I need a picture of the board!
not off the table around it ;)
Use a macro to take a picture
It is very fuzzy
Can you see anything on your images???
ELIO65
Post by ELIO65 »
:roll:
:roll:
can not read the number of the Chip in an red frame ?
I think your Problem ist not the ELM
Control your Setting / Interfaces Setting / Com port /
and you can read your ECU
For ABS / Airbag / usw. you need an yellow Adapter
puntomjtd1234
Post by puntomjtd1234 »
hello
I have a problem with the connection to the ECU with a Chinese clone bluetoth.
The connection bluetoth is ok and the interface is regularly recognized but when I try to connect to the ECU interface software warns you that the connection is impossible.
In addition, the test code AT brings a positive response or negative randomly
I attach screenshots (OBDII.docx) and photos of the device.
Thanks for the reply
OBDII.docx
(577.87 KiB) Downloaded 416 times
Hello puntomjdt1234
Wich CAR / model / year want you read ????
I dont can read the number from the Chip in the yellow frame ??
And thr resistor in blue frame ???
You can remove the white plastik Connector from the Board ?
back markiert.jpg (71.7 KiB) Viewed 6856 times
front markiert.jpg (67.93 KiB) Viewed 6856 times
puntomjtd1234
Thanks Alfaeddy.
This evening I send photos with details that you asked me.
The car is a Fiat Punto 1.3 mjtd 2005.
Hello puntomjtd1234
If this is your Punto??
Punto 1.3 mjtd.jpg (86.56 KiB) Viewed 6848 times
Then you should be with your interface to connect to your ECU can produce without removing a resistor on the board.
The ABS should be read with green adapter without modifiktation
Send me other times images
puntomjtd1234
Hello Alfaeddy
Yes,that it is my car.
The chip in the yellow frame is a MCP2551
The resistor in the blue frame is marked 473
Under the plastic connector there is the resistance R04 but I can not read the value.
To remove the white plastic connector I have to desolder it.
If you think it may help you understand I can do it.
Thanks again for your help
This ELM you can without modification and read your ECU with a green adapter also the ABS
If this is not possible there is a setting error
But for service reset, Body Composition, CAN setup etc., there may be problems
This resistor R04 he connects the two pins in the picture??
front markiert R04.jpg (68.39 KiB) Viewed 6835 times
If this is so?! remove R04
So you can read CAN bus protocol
