Angel
Post by Angel »
Hello guys I have a
FIAT 500 0.9 twinair 2016 Cabrio
I installed uconnect nav7” and followed the instructions here for bytes length and everything went smooth except now I get EOL FAILED for the airbag and when I try proxy it is timing out on the airbag my custom proxy is bellow
33 32 31 35 30 30 32 39 39 33 32 4F 55 54 50 55 54 44 4A 49 54 20 16 01 08 4F 8C 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 42 75 06 F4 20 1C C0 30 10 00 16 00 01 08 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 40 2E 24 00 00 00 00 32 05 68 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 94 00 22 00 04 93 02 00 20 80 00 00 44 00 D5 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 D1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Can anyone help me with this? Thanks in advance
chrener
Post by chrener »
Hi on some 500s is the fault in passenger seat detection or passenger seatbelt reminder...
Unplug the yellow connector below the passenger seat
and run proxialignment...
Jeep Renegade 1.4 MultiAir TURBO 75th Anniversary
Angel
Post by Angel »
budgoz wrote: 03 Mar 2023, 18:08 Hi guys, send me your proxy if you want to change the graphic to the abarth version.
Hellos I would like to have the Amarth version on tachometer here is my proxy thank you in advance
Angel
Post by Angel »
chrener wrote: 29 May 2023, 10:21 Hi on some 500s is the fault in passenger seat detection or passenger seatbelt reminder...
Hi thanks for your response but I tried and it’s not that
This started after adding the uconnect 7” before this everything was eol ok and proxy was not needed
MCHL500
Post by MCHL500 »
I just wanted to kick my question below in a subtle manner... Thanks!
MCHL500 wrote: 09 May 2023, 11:35 I have a (early) 2017 Fiat 500 with Uconnect 7. Currently, CarPlay is not activated. Is it possible to find out if my unit supports CarPlay, using Multiecuscan and proxy alignment? Can I read version details from the display or do I need to take out the head unit to look at the label on the back? Thanks for your support!
chrener
Post by chrener »
So, problem is in uconnect setting in proxi...
Did you set radio correctly?
Did you extend proxi lenght?
Angel
Post by Angel »
Probably I did a mistake while editing the proxy.
Yes I did extend the proxy the uconnect is eol ok everything is working I am just having eol failed to airbag
chrener
Post by chrener »
I had the same issue in airbag node and when i looked to FESlog after proxialignment, node asks for change byte 69 i f remember right.
After byte value change passenger seatbelt reminder still runs alarm also with empty passenger seat... Of cousre after seatbelt lock it was OK...
I solve it with unpluged seat nonnector and then proxialignment done with success with original airbag node settings...
EDIT:
As i see in your proxi - you have 69=0C, try to aligned with 69=04
Angel
Post by Angel »
Hello chrener thanks for your reply it was not this the problem. The problem was that my friend who tried to do the proxy in the first place had connected on the 1.2 version and not 0.9 as a result a lot of pieces of the coding has changed and after that we had no hope even if we connect as 0.9 so I went to a guy who have a similar car and I copied his proxy but the first bytes added from me because is the Florence code it is until the second 4F.
Sambergwkd
Post by Sambergwkd »
abarthmultijet wrote: 06 Apr 2022, 20:26 No problem, hope you are happy with it.
Try to plug in your phone, this code supports apple carplay/ android auto. If it doesn't work i know how to activate it. Send me a PM!
Hi Abarthmultijet,
I would like to get in touch with you about the following. We have just bought A 2017 500 0.9 TwinAir Turbo 80hp with 7” Uconnect with TomTom and DAB but to oud dissapointment without the CarPlay function. I ding have multiecuscan but there is A tuner in my country that works with it. I am hoping to hear from you if and how its possible to activate CarPlay. But i could not yet sent you A private message.
Kind Regards Sam Berg.
