Closing windows with the remote key AR 147
viewuser
Re: Closing windows with the remote key AR 147
Post by viewuser »
TribesMan wrote:OK, now if I understand this right...
Inside windows controller there is a circuit consisting of +5V -> 1k -> 1N4148 -> pin 2/3 (or 9/8 for passenger window) of the H44 connector. So one pin of the window pinch sensor is connected to the microprocessor, and the other pin is connected to GND.
Then all you have to do is to connect 2 components on the outside of the windows controller. 1k5 resistor wired in series with 1N4148 diode.
Correct me if I'm wrong.
Hi all,
it's works on my ALFA 147 2004 !!!
Thank people, thank Yani !
8-)
alfa147
Post by alfa147 »
Hi All,
it works perfect also on my AR 147 2006, both front and rear windows! :)
Just had to take apart windows ECUs and insert the resistors inside them.
Thanks Yani for the GREAT job!
max147
Post by max147 »
Hello ...
I have an Alfa 147 jtd, 2002. I want to make the change to close the windows with the remote control ....
I can do with the change of resistance and diode, or do I upgrade the body computer?
Thanks to all
dallas140cv
Post by dallas140cv »
In my 2004 147 this feature don't work, with the original door ecu and with a door ecu enabled for windows remote closing and the anti-pinch simulation. With this ecu, some years ago, I had the remote closing before proxy alignment. Now, the anti-trap sensor enabling is not definitive, if I close FES and turn off the key and so I turn on the key and open FES, on BC the anti-trap are "not present", also with the door ecu with resistors.
dallas140cv
I have to make another test.... I haven't made the proxy alignment after changing the anti-trap presence flag :twisted:
