Page 45 of 257
Posted: 22 Dec 2012, 15:51
Hello Stapy
To get to your CAN controllers you need to open the ELM and remove on the lower PCB resistor R2 (121).
Then you can to control, CAN info / setup, service access, etc..
In the picture I marked red the resistor R2.
- ELM Mini.JPG (192.21 KiB) Viewed 13694 times
- ELM mini markiert.jpg (225.77 KiB) Viewed 13694 times
Then add the ELM mini back together and glue the housing
To get to your bag you have the KKL interface either use the adapter 2 or open the KKL and solve the pin 7 and replace the pin 3
Posted: 23 Dec 2012, 21:12
by stapy
Eddy
you are the man, i can get the air bag now, i got this error "08 - Driver squib circuit"... thx man.... another favor i want to access "air bag" and dashboard...please help me with this
thx in advance Eddy for your help, i really appreciate this help
Posted: 23 Dec 2012, 22:33
Hello Stapy
To get to the dashboard you need to change your ELM interface as described.
Removing resistor R2
Then you should make the remaining connections.
Posted: 23 Dec 2012, 22:38
by pleinlesyeux
I took the plunge and remove the R04 resistor of my elm327.
The board is not like any posted on this thread.
I can access the service reset now, and the boddy, but whenever I connect the red or yellow interface, nothing gets recognized.
What can I do ?
Posted: 23 Dec 2012, 23:09
That's all right, then, for your airbag at the Alfa 147 you need a KKL interface and the red adapter
The yellow adapter you need not even needed for Mito and Giulietta.
Posted: 24 Dec 2012, 11:37
by stapy
THX Eddy... thx for everything
Posted: 27 Dec 2012, 14:24
by Alfa159_2
Dear community
Let me introduce myself quickly.
My name is Marcel and I am a - proud
- owner of an Alfa 159 TBi.
Have started to play recently with an ELM 327 ( rev 1.5) interface on my car.
Here is my issue:
During the SCAN (F11) I don't see the engine ECU of my car ( should be a Motronic). All other modules show up (steering lock, body ECU ... c.f. attached).
I would expect that the engine ECU also shows up during the scan, even if I cannot connect properly because I use the free version of multiecuscan.
Can somebody confirm that, or is that a problem sombody else has already had ?
My plan is to purchase the registered version of Mutiecuscan, but I want to make sure that there is not a problem somewhere else.
Note that I have tested my interface on a Lancia Musa 1.3 and it seems to work fine ( can access all items that are supported by the free version).
Also latency time of the com interface has been set to 1. Baud rate 38400.
Here are the results of the scan:
Scanning ...
Electric SteeringSteering Lock TRWISO Code: 04 07 04 04 68BodyBody Computer MarelliISO Code: 40 83 1F 04 3BBodyTEG Reader TRW (Electronic key)ISO Code: 6E 07 01 04 4FDashboardInstrument Panel SiemensISO Code: 32 83 9E 04 2CDashboardConvergence Marelli/Microsoft C3 (Blue&Me Nav)ISO Code: B5 83 8C 85 9EClimate controlDelphi climate control (Dual/three zone)ISO Code: 34 83 0B 04 9BOtherDriver's Door G.E. PROCONDISO Code: 86 07 8C 04 F2OtherPassenger's Door G.E. PROCONDISO Code: 89 07 08 04 F1OtherBoot G.E. PROCONDISO Code: 07 07 08 04 EFOtherParking Control VALEOISO Code: 3E 83 83 01 1A
COMPLETED
Feedback is much appreciated.
Thx !
Posted: 27 Dec 2012, 15:22
The motor control your 1.8 TBi is not yet supported by the Multiecuscan
If you look at the controls of the Alfa 159, you will see that there is no motor control.
When Yani the integrated into the software, he can only answer yourself
Posted: 27 Dec 2012, 20:57
by Alfa159_2
Hello Eddy,
Thanks for your feedback.
Have checked the compatibility list again, and indeed for the first 1.8l engine no motor control ECU shows up.
On the second 1.8 however,the list contains a motor control ECU.
The second engine should be the Alfa 1.8 turbo engine. The first, I guess , is the engine sourced from GM.
Hope that the list is correct and that the code already supports the 1.8l turbo engine today.
As you say, Yani can most probably confirm.
Thx again !
-M
Posted: 02 Jan 2013, 14:47
by alikut99
this is my elm 327
how to fix it?
- DSC_0257.jpg (903.84 KiB) Viewed 13538 times
